S2K service bulletins
Old Aug 13, 2001 | 11:00 AM
kingpin's Avatar
Default S2K service bulletins
Report Date: August 13, 2001 02:34:18 PM
Service Bulletin Number: 010999
Bulletin Sequence Number: 800
Date of Bulletin: 9909
NHTSA Item Number: SB608007
Make: HONDA
Model: S2000
Year: 2000
Component: MANUFACTURERS INFORMATION TO DEALERS
Summary: INFORMATION ON NEW S2000 ROADSTER. *TT
Service Bulletin Number: 000101
Bulletin Sequence Number: 103
Date of Bulletin: 0001
NHTSA Item Number: SB610337
Make: HONDA
Model: S2000
Year: 2000
Component: INTERIOR SYSTEMS:SEAT AND SHOULDER BELTS AND BELT ANCHOR:OTHER PARTS
Summary: INFORMATION ON REPLACING THE SEAT BELT TENSIONERS. *TT
NHTSA Item Number: SB610347
Make: HONDA
Model: S2000
Year: 2000
Component: EQUIPMENT
Summary: INFORMATION ON HOW TO USE THE PGM TESTER OR SCAN TOOL. *TT
Service Bulletin Number: 00037
Bulletin Sequence Number: 125
Date of Bulletin: 0004
NHTSA Item Number: SB612554
Make: HONDA
Model: S2000
Year: 2000
Component: VISUAL SYSTEMS
Summary: VEHICLES MAY EXPERIENCED THE REAR WINDOW THAT IS CREASED, CLOUDED, OR SCRATCHED. *MJS
Service Bulletin Number: 00057
Bulletin Sequence Number: 140
Date of Bulletin: 0007
NHTSA Item Number: SB614082
Make: HONDA
Model: S2000
Year: 2000
Component: EQUIPMENT:ELECTRIC EQUIPMENT:RADIO:TAPE DECK ETC.
Summary: A CONDITION MAY EXIST WHERE THE SOUND CUTS OUT FROM ALL SPEAKERS WHILE PLAYING A CD AT HIGH VOLUME. THE SYSTEM DISPLAY STILL WORKS, BUT THE SOUND WILL NOT RETURN UNTIL THE SYSTEM IS TURNED OFF AND BACK ON AGAIN. *TT
Service Bulletin Number: 00054
Bulletin Sequence Number: 156
Date of Bulletin: 0012
NHTSA Item Number: SB615716
Make: HONDA
Model: S2000
Year: 2000
Component: POWER TRAIN:TRANSMISSION:UNKNOWN TYPE
Summary: WHILE DECELERATING IN 3RD OR 2ND GEAR, A BUZZING OR RATTLING COMES FROM THE ENGINE OR TRANSMISSION BETWEEN 4,000 AND 3,000 RPM. *TT
Service Bulletin Number: 171100
Bulletin Sequence Number: 157
Date of Bulletin: 0011
NHTSA Item Number: SB615764
Make: HONDA
Model: S2000
Year: 2000
Component: INTERIOR SYSTEMS:ACTIVE RESTRAINTS:BELT RETRACTORS
Summary: INFORMATION REGARDING MISPACKAGED SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 011100
NHTSA Item Number: SB615766
Make: HONDA
Model: S2000
Year: 2000
Component: EQUIPMENT:ELECTRIC POWER ACCESSORIES:SEATS
Summary: SUBJECT REGARDING CAMPAIGN PARTS AVAILABLE FOR OPEN ORDERING - SEALT BELT SENSOR KIT. *TT
Service Bulletin Number: 01008
Bulletin Sequence Number: 178
Date of Bulletin: 0101
NHTSA Item Number: SB617862
Make: HONDA
Model: S2000
Year: 2000
Component: EQUIPMENT:ELECTRIC POWER ACCESSORIES:WINDOWS
Summary: ON SOME VEHICLES, WHEN THE TOP IS LOWERED OR RAISED, OR THE DRIVER'S TRYS TO USE THE AUTO DOWN FUNCTION FOR THE POWER WINDOW, THE WINDOW GOES DOWN ONLY 3 OR 4 INCHES. THE WINDOW GOES DOWN ALL THE WAY IF YOU PSH AND HOLD THE POWER WINDOW SWITCH. *TT
Service Bulletin Number: 181000
Bulletin Sequence Number: 188
Date of Bulletin: 0010
NHTSA Item Number: SB618917
Make: HONDA
Model: S2000
Year: 2000
Summary: SUBJECT REGARDING SEAT BELT RETRACTOR RECALL UPDATE. *TT
Service Bulletin Number: 031000
Bulletin Sequence Number: 189
NHTSA Item Number: SB618929
Make: HONDA
Model: S2000
Year: 2000
Summary: SUBJECT REGARDING RECALL ANNOUNCEMENT AND STOP SALE ORDER FOR 2000 MODEL YEAR VEHICLES EXHIBITING THE SEAT BELT RETRACTOR THAT MAY OCCASIONALLY LOCK UP WITH THE BELT FULLY RETRACTED. *TT
Service Bulletin Number: 011000
NHTSA Item Number: SB618933
Make: HONDA
Model: S2000
Year: 2000
Summary: LETTER TO SERVICE MANAGER REGARDING SAFETY RECALL 00-078 - S2000 SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 00078
NHTSA Item Number: SB618934
Make: HONDA
Model: S2000
Year: 2000
Summary: PRELIMINARY SERVICE BULLETIN REGARDING SAFETY RECALL - S2000 SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 010200
Date of Bulletin: 0002
NHTSA Item Number: SB618951
Make: HONDA
Model: S2000
Year: 2000
Component: ENGINE COOLING SYSTEM:OTHER PARTS
Summary: BRIEF INFORMATION ON DIAGNOSING ENGINE COOLANT TEMPERATURE SENSORS AND TEMPERATURE GAUGES. *TT
NHTSA Item Number: SB618955
Make: HONDA
Model: S2000
Year: 2000
Component: ENGINE
Summary: INFORMATION ON THE S2000 ENGINE AND OIL CONSUMPTION. *TT
NHTSA Item Number: SB618958
Make: HONDA
Model: S2000
Year: 2000
Component: ENGINE
Summary: INFORMATION ON HONING FIBER REINFORCED METAL (FRM) CYLINDERS. *TT
NHTSA Item Number: SB618959
Make: HONDA
Model: S2000
Year: 2000
Component: POWER TRAIN:TRANSMISSION:AUTOMATIC:CONTROL MODULE (TCM, PCM)
Summary: BRIEF INFORMATION USED WHEN ORDERING PARTS FOR SERVICE BULLETIN 00-055 - GRINDS WHEN SHIFTING INTO 2ND GEAR. *TT
NHTSA Item Number: SB618962
Make: HONDA
Model: S2000
Year: 2000
Summary: INFORMATION ON PROGRAMMING IMMOBILIZER KEYS. *TT
NHTSA Item Number: SB618968
Make: HONDA
Model: S2000
Year: 2000
Summary: INFORMATION ON REPLACING VINYL REAR WINDOW. *TT
Service Bulletin Number: 010400
NHTSA Item Number: SB618982
Make: HONDA
Model: S2000
Year: 2000
Component: AIR CONDITIONER:COMPRESSOR
Summary: SUBJECT REGARDING A/C COMPRESSOR MOUNTING BOLT TORQUE. *TT
NHTSA Item Number: SB618992
Make: HONDA
Model: S2000
Year: 2000
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary: INFORMATION ON RESETTING THE MAINTENANCE REQUIRED INDICATOR. *TT
NHTSA Item Number: SB618997
Make: HONDA
Model: S2000
Year: 2000
Summary: INFORMATION ON THE SERVICE MANUAL INDEX. *TT
Bulletin Sequence Number: 199
Date of Bulletin: 0103
NHTSA Item Number: SB619919
Make: HONDA
Model: S2000
Year: 2000
Summary: EXPERIENCING A BUZZ OR RATTLE FROM THE ENGINE OR TRANSMISSION WHILE DECELERATING. *TT
Service Bulletin Number: 01038
NHTSA Item Number: SB619927
Make: HONDA
Model: S2000
Year: 2000
Component: STRUCTURE:BODY ROOF:CONVERTIBLE TOP
Summary: ON CERTAIN VEHICLES, THE REAR PART OF THE CONVERTIBLE TOP COVER DOES NOT STAY TUCKED IN. *TT
Service Bulletin Number: 00083
NHTSA Item Number: SB619954
Make: HONDA
Model: S2000
Year: 2000
Summary: THIS BULLETIN STATES THAT IN HUMID CONDITIONS, WITH THE A/C ON AND THE FAN RUNNING AT MAXIMUM SPEED, WATER DRIPS ON THE PASSENGER'S CARPET. *TT
This search returned 25 records.
Miike505
South Florida
Jul 29, 2006 03:14 AM
ugur
Feb 8, 2003 02:23 AM
enguyen7292
38
Aug 21, 2002 09:54 AM
THRILLR
Apr 24, 2002 02:56 PM
Dorian Gray
Jan 31, 2002 09:41 AM
