Safe a/f ratio?
Originally Posted by Emil St-Hilaire,Mar 17 2006, 09:48 AM
Get it dyno tuned.
Whatever you do,do not play it by ears;way too dangerous.
I think I remember reading somewhere in F/I that an A/F ratio of 12 is dangerously lean, and 18 is alot better. Sorry if I sound like a noob, but I'm trying to learn as much info as I can. What would happen if you went too lean? Would the engine just stall? Wouldn't it be worse to go too rich?
[QUOTE=Mikes256,Mar 17 2006, 07:28 AM] I think I remember reading somewhere in F/I that an A/F ratio of 12 is dangerously lean, and 18 is alot better. Sorry if I sound like a noob, but I'm trying to learn as much info as I can.
Banned
![](https://www.s2ki.com/forums/images/s2ki/ranks/banned.png)
Banned
Originally Posted by wet_poo,Mar 17 2006, 07:30 AM
12 is rich and 18 is way lean.
A safe a/f is dependant on engine load. You can go pretty lean under high vacuum.
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
13.4 under WOT should be safe while still getting nice power!
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
for NA... should be somewhere around 13.5~14.7(limit?) for max performance.. F/I ppl should run no greater than 12... running over 12wot, with boost u are walking on thin ice.
