seats are stuck
Old Apr 8, 2006 | 08:27 PM
ladius's Avatar
Originally Posted by SilverKnight,Apr 8 2006, 07:43 PM
WD 40?
Yes, i did try WD-40 but I don't think I was able to spray it where it counts. I can't quite to the inner rail towards the rear.
Old Apr 9, 2006 | 02:41 AM
RACER's Avatar
Originally Posted by ladius,Apr 8 2006, 09:26 PM
btw, still interested in getting those seat locks of yours... once i get my damn seats off!
I dun't think you will be needing the seat locks
Old Apr 9, 2006 | 04:38 AM
JDR159's Avatar
Some additional ideas. Use penetrating oil, not wWd-40. Get a light and look under the seat and spray all the rail components on both sides. Let sit for 10', go back, and spray again and wait again. Take a screw driver, or metal bar of the right length, and place the end on the rail component attached to the seat. Use a hammer to pound on the screw driver/rod. Use a fair amount of force (but of course don't bend any of the locking fingers) and do this on both sides. This pounding with the penetrating oil should break the rust free..
Good luck.
Old Apr 9, 2006 | 05:17 AM
Will's Avatar
i've had good luck using PB Blaster on stuck parts.
Old Apr 9, 2006 | 09:52 AM
ladius's Avatar
Thanks for the tips. I'll try penetrating oil--is PB Blaster one of them? And yes, striking the rails seems like a good idea. I'm gonna try that and keep y'all posted.
thanks again!
hopefully, i will need those seat locks!
Old Apr 9, 2006 | 12:38 PM
JDR159's Avatar
PB Blaster is a penetrating oil. Just go to any auto parts store and ask them what is the best stuff they have.. BTW, don't hit the RAILS, they're bolted down and won't move. You want to hit the brackets bolted to the SEATS. They're what move. When you hit them, it helps the penetrating oil flow into the crevices, and acts like an impact wrench to break the parts loose..
Old Apr 9, 2006 | 02:15 PM
ladius's Avatar
Ok, I got some penetrating oil, the NAPA brand, and sprayed it liberally on the rails area. I tried hammering carefully at the brackets bolted to the seats but nothing gives, yet. I'll let it sit a day or so, hopefully the hammering worked some things loose and will be able to work its way in there.
thanks again everyone. I'll let you all know.
Old Mar 27, 2007 | 12:07 PM
Ed_Grant's Avatar
bump
I'm all ears.
Old Mar 27, 2007 | 12:50 PM
plokivos's Avatar
i bet something is stuck on the rail. that happens often.
mostly my lighter.
Old Mar 27, 2007 | 03:08 PM
Kodokan_4's Avatar
Originally Posted by Ed_Grant' date='Mar 27 2007, 12:07 PM
bump
I'm all ears.
I hope he got it by now. It's been a year.
-Pete
