Shifter Feel
Old Mar 13, 2006 | 12:31 PM
  #31
Race Miata's Avatar
Originally Posted by Ronin2k,Mar 12 2006, 03:50 PM
What works perfect for me is stepping on the clutch feeling the moment it engages then click it into gear. If I wait for the clutch to be depressed all the way down it tends to be notchy for me.
Exactly what I meant in my lengthy post above. If you wait til one event to finish before working on the next, that's too slow. Again, I'm not saying to rush the shift. Get the hand ready for the shifter. Think like the clutch as a handle to pull open an imaginery gate holding the shifter. As soon as the clutch pedal reaches the disengagement point, the shifter is free to go.
In fact, in my super responsive miata, I always applied a mild force on the shifter towards shifting out of the gear when I depress the clutch. The driving torque from the engine will generate enough friction to keep the synchro hub locked. As soon as the clutch hit the disengagement point, the friction was gone and it felt like a gate open and the shifter dropped out of gear. This gave shortest delay without rush to shift smoothly on the super responsive car.
Old Mar 13, 2006 | 12:54 PM
  #32
Race Miata's Avatar
Originally Posted by j5669,Mar 12 2006, 04:35 PM
Shifting is only notchy for a short while, after a few miles its smooth, is it more forgiving when its warmed up? This change obliviously has nothing to do with me changing my technique.
Because you need to change your shifting style for cold. I've read about AP2 delays dropping engine speed on lifting. If that's Honda's strategy to address complaints to notchy shifter then it's another thing for me to feel ashame of Honda after the CDV. If this engine speed drop delay time period is not strategically lengthened when cold, then what you AP2 folks need to do when shifting in the cold is just like I said before -- lift less and later. Check engine speed when you release the clutch. If engine speed needs to climb up on clutch release, lift less and later on upshift in the cold.
Like I've said before, when engine oil and transmission fluid are cold, they are thick and therefore engine and tranny input shaft speed drop much faster. The key is to change your shift timing for the 1st mile or so to lift less and later. You don't need to rush the shifts. Just lift less and later for the shifts. When I do that on my AP1, my shifts in the cold are just as slick as both engine and tranny are at operating temperature. When you get the revs right, you don't really need the help from the synchros even in the cold. Like I said before, I can even upshift without clutch or grind or resistance in the cold for illustration. That tells you how little I rely on the synchros.
Old Mar 13, 2006 | 12:56 PM
  #33
Race Miata's Avatar
[QUOTE=smurf2k,Mar 12 2006, 04:50 PM] shifting problem?
Old Mar 13, 2006 | 12:58 PM
  #34
Race Miata's Avatar
Originally Posted by Mikes256,Mar 12 2006, 04:51 PM
Are you referring to when you let the clutch out, after you have selected the new gear? because I get that too from 1st to 2nd. I'm thinking it's the clutch delay valve throwing the timing off, but I don't know for sure because this is my first MT car
Correct me if I'm wrong, but I think CDV only affects high rpm shifts in racing condition. I think it has little effect on normal driving if you get the shift timing right.
Old Mar 13, 2006 | 01:01 PM
  #35
Race Miata's Avatar
[QUOTE=smurf2k,Mar 12 2006, 04:57 PM] probably it is the delay valve.
Old Mar 13, 2006 | 03:37 PM
  #36
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Man of a few words.!
Old Mar 13, 2006 | 05:55 PM
  #37
Race Miata's Avatar
Hmmm... Does that refer to me? I have not even 1/3 of your PPD.
Old Mar 13, 2006 | 09:11 PM
  #38
RED MX5's Avatar
I know he ain't talkin' about me!
This may be my shortest post ever.
Old Mar 13, 2006 | 09:24 PM
  #39
Mikes256's Avatar
You could be right. This is my first manual transmission car, so i'm learning as I go. I tried what you said about "Shifting faster but don't rush it" and it really seems to work. Now i'm practically overlapping each step, and the shifts feel a lot smoother.
For example, when I push the clutch down and I feel it disengage, I start to move the shifter into the neutral gate as I continue to push the clutch to the floor. Then as i'm pushing the shifter into the new gear i'm already starting to bring the clutch back up, and by the time the new gear is selected the clutch engages and I continue to fully release the clutch. This is a lot smoother than my previous granny shifting technique I hope i'm doing it right
Old Mar 13, 2006 | 09:32 PM
  #40
RED MX5's Avatar
[QUOTE=Mikes256,Mar 14 2006, 01:24 AM]You could be right.
