Shifting Techniques
Originally Posted by Race Miata,Mar 15 2006, 12:29 AM
Did you (or do you) find my post and the rest of the thread help anything?
Thanks for your help!
This is an interesting thread. I learned to drive manual cars only about 5 years ago and was self taught. Being smooth was much more difficult than being fast. For smoothness at almost any engine speed I learned to let off the gas before touching the clutch or the shifter.
Roll off the throttle slowly but never all the way off, then make the change to the next gear and slowly get back on the throttle, the timing would depend on the car you are driving. With this I can have a passenger hold a full cup of water and never even see the water level change let alone spill anything. There is no discernible jerk to either myself or the passenger.
Flat shifting is another story
For normal daily driving the 1-2 shift should be at a slighly lower RPM and the clutch is "feathered" or "slipped" slightly to create the smooth transition...
If you are banging gears and want a high rpm shift...you need to really have the timing down. In this case you DO NOT FEATHER OR SLIP the clutch because you are throttling much harder than for normal daily driving. If you do not time the shift and throttle before you are off the clutch... you will decrease the longevity of your clutch and you will smell it at the next stop light.
Tim
Tim
[QUOTE=SIIK2NR,Mar 15 2006, 09:39 AM]For normal daily driving the 1-2 shift should be at a slighly lower RPM and the clutch is "feathered" or "slipped" slightly to create the smooth transition...
Ok, I tried this tonight, but wasn't as successful as I hoped. I can smoothly shift if I'm really careful with shifting and feather the clutch, but I'm trying to master what Race Miata's suggesting.
A few basic questions to help me rethink my shifting:
- When upshifting, should I completely let off the gas or keep pressing a little?
- If I get the upshift timing right, I should be able to instantly let go of the clutch instead of feathering it?
- When upshifting, am I trying to let the rpm drop to some magical number before letting go of the clutch (ie rev-match)?
- Should clutch and gas be balanced (press gas as I let go of clutch) or are they two separate processes?
- Should I press the clutch in all the way or just to the engagement/disengagement point?
Thanks!!!
Thanks!!!
Originally Posted by Race Miata,Mar 15 2006, 12:06 PM
Even for normal driving, you don't feather the clutch or gas to finish off an upshift in order to perform a smooth engagement. It's OK to do it while you're learning, but there's no reason why you need to rely on feathering the clutch and gas for a smooth upshift if you catch the exact timing to engage the clutch.
I was referring to the 1-2 shift ONLY, not all the gears. Additionally that was the only shift he was having problems with during normal driving.
A lot of factors involved in a smooth upshift on the 1-2 shift. Are you going downhill?...uphill and at what RPM you are shifting...
If your saying you can do the 1-2 shift at any RPM without balancing the clutch/gas then I'm calling
Put a passenger in the car and watch there body and head movement..... clutch/gas balance on the 1-2 shift is normal if you ask me and it doesn't effect "timing" for the spirited shifts at all.
JMO..
Tim
Originally Posted by Race Miata,Mar 16 2006, 01:32 AM
Yes, but if you don't feel confident that you can do it right every time, then release half way in one quick shot first (any rev mismatch will turn into smooth clutch slip here) and then release the rest in another shot.
This is the advice I was giving him.. essentially releasing half way is a smooth slip...
I THINK we are on the same page...
