Shifting while taking a slight curve
Originally Posted by s2kobsession,Sep 16 2008, 01:32 PM
it's really not that hard.
Pull straight back for 4th
pull back and towards yourself for 2nd
and pull back and away from yourself for 6th.
repeat the above steps for 1st, 3rd and 5th.
You should not aim for a gear, apply pressure in the direction of the gear you want for the (4) outside gears. For third and fourth you should let the spring mechanism do it.
From fifth to sixth you should still be applying pressure away from you, not "aiming" straight back.
try shifting with this technique. it helped me a lot after i had mis shifted and was worried about doing it again. click here
If you're shifting to 4th in a curve, you're going around 80 mph... if the g forces are high enough that you're having trouble shifting, I'd be worried about upsetting the balance of the car by shifting at all. Even if you're going around a curve, everything in the car is still in the same place even if you side around a bit.
At any rate, I'd focus not on pulling the shifter but on pushing it - you need only a light touch - two fingers - and it will naturally drop into 4th. The 3-4 shift is the easiest shift since that's the natural balance for the shifter.
if your gettin on it try sitting in proper racing seat position. you should be able to press you butt to the back of the seat with the dead peddle, foot flat. from there i cant really see you having any problems with shifting straight.
Unless you're at redline 3-2 is nothing - it's 5-2 you have to watch! Agree completely w/Saki: Have braking & shifting completed as you enter the turn then let the laws of physics & the car's suspension do their work. As you exit the apex the car will recover its equilibrium. At that point you should be shifting down to maintain RPM, not shifting up, which will lug the motor.
s2k_redhead
Dec 17, 2003 04:01 PM
