slowing down for a turn and then what?
Old Jan 19, 2004 | 10:37 AM
  #21
koala's Avatar
Lets keep it simple. Before you go into a corner, push the clutch in, select the lower gear, and slowly let the clutch out.
Apply brakes before or after downshifting, whichever you're comfortable with. Go thru the corner, accelerating after you are half-way thru, get back to cruising speed, clutch in, select higher gear, clutch out (no gas required).
That is the newbie way to do it.
Practise this, then go onto this step:
Do what you did before, but this time, push the clutch pedal in, select the lower gear, now, before you let out the clutch, "blip" the throttle, raising your engine speed about 1000 RPM. Let off the clutch reasonably fast (not as slow as you normally would). This will speed match your trans. components, for a smoother (and faster) downshift, and it will also prevent some wear on the components.
Once you are good at blipping the throttle on a downshift, then move onto heel-toe... but I won't explain that yet.
I taught my little brother how to blip the throttle on just his second experience in a manual tranny car... and now he owns an '04 Mazda3 5 speed, which I have now taught him how to heel-toe on, and he's doing great after barely 900 miles on the car.
practise makes perfect.
Old Jan 19, 2004 | 12:44 PM
  #22
Muz's Avatar
Muz
Former Sponsor
Originally posted by [ llcrayonll |>
i don't think you should be worrying about heel and toe just yet... you might get confused and panic, which won't be good. if you want a really really simple way to take a corner for daily driving, just do this:
as you're coming to a turn, just throw the car into neutral and use your brakes to coast into the turn. take the turn at a comfortable speed, say 15-20 mph. once you've made the turn, or maybe during the turn, put the car in second gear and you're done.
I disagree. Being in neutral IS a bad thing when cornering. A driver should never ever coast his car into a turn. I'm sorry, my intention is not to offend you but this is extremely bad advice. A coasting car is almost as good as a car without a driver behind the wheel. You do not have full control of a coasting vehicle.
Doing it at 15-20 mph where he might get away with it is teaching him incorrect principles of driving and one day he might try it at 50mph and end up wrapped around a post.
Old Jan 19, 2004 | 12:50 PM
  #23
nastinupe1's Avatar
Usually I slow down then turn the wheel then drive through the turn then speed back up again.
I hope that this helps.
Old Jan 19, 2004 | 01:06 PM
  #24
PrimoAP1's Avatar
And don't say V Teching anymore
Old Jan 19, 2004 | 01:10 PM
  #25
krazik's Avatar
Administrator
[QUOTE]Originally posted by Muz
Old Jan 19, 2004 | 01:23 PM
  #26
[ llcrayonll |>'s Avatar
i agree also, muz. i'm not suggesting he should continue to drive like that, just trying to find a way to minimize any thought out of it. but the way you put it, i realize that it is bad advice. probably be best to just shift into 2cd gear at the appropriate speed BEFORE the turn, just because i'm concerned he's not ready to shift and turn at the same time. not something to learn on the open road.
Old Jan 19, 2004 | 02:58 PM
  #27
joe52985's Avatar
not totally sure but i think you guys are looking farther into the question then he wants im guessing what you want to know is if your moving, not giving it gas and have the clutch in, can you let off the clutch without gassing it(?). not sure if i would recommend it because it may be un-needed stress on the synchros. but as long as your going say, 30 in say, 3rd gear (not too too sure of s2000 gear ratios so bear with me) you should be able to let off the clutch without gassing it and just sorta coast thru the corner while still have power on demand
Old Jan 19, 2004 | 03:03 PM
  #28
rworne's Avatar
Jeez, give the guy a break. The S2000 is my first (manual RWD) car and I don't drive it like a madman. Learning is half the fun as long as you don't get too cocky.
Not every new driver is out to jack up your insurance rates.
Old Jan 20, 2004 | 12:19 AM
  #29
thongfoto's Avatar
Seven11
Apr 7, 2021 10:50 AM
acn684
May 15, 2012 07:00 AM
LostWaffle
Jan 3, 2003 10:31 AM
swells65
Feb 17, 2002 08:49 PM
tom717
May 19, 2001 11:27 PM
