small soft top tear question
Old Mar 4, 2012 | 02:53 PM
DallasAp1's Avatar
Default small soft top tear question
well it happened. my soft top has a very small pencil tip size tear in the typical wear spot. i dont know if it even leaks but its only visible from the inside of the car.
i want to just put a little bit of the adhesive vinyl stuff ive read about other people using is there any particular brand people recommend? and where do they sell it? i just dont want to rush to order it and get the wrong kind.
Old Mar 4, 2012 | 04:14 PM
redlineracing's Avatar
I used a product called " Tear Aid" on mine,worked great.
Make sure you get the product for fabric.
Lot's on online vendors have it....I got mine here>
http://www.amazon.com/s/?ie=UTF8&key...l_3wxvc5t6jq_b
\rlr
carolina
Old Mar 4, 2012 | 08:40 PM
Zoomie's Avatar
I used STORMSURE and was pretty pleased
Old Mar 4, 2012 | 09:00 PM
meccjoo's Avatar
\rlr
carolina
tear aid is awesome, i used it on my old ap1. it sealed up a couple of tears and kept them from getting worse. i put a few patches on my current s2k in the typical wear spots to prevent tears and so far so good.
Old Mar 4, 2012 | 09:56 PM
DallasAp1's Avatar
\rlr
carolina
http://www.amazon.com/Tear-Aid-Type-...0930557&sr=8-4
is that the one you ordered?
Old Mar 5, 2012 | 03:21 AM
charliec225's Avatar
I'm going to be attempting a little repair this week if time allows. I'm going to:
1. Stitch up the tear.
2. Apply Loctite Vinyl Adhesive to either side to seal the stitching and help hold the repair.
3. Apply a large iron on patch to the inside to reinforce and smooth the surface the bar runs across.
4. Cover the outside stitched/sealed area with 3M Vinyl Repair to hide and reinforce the repair.
I used tear-aid and other patches, and they kept eventually getting pulled up. Plus (at least for me) they seem to do more to seal the hole than actually prevent the hole from getting larger.
Old Mar 6, 2012 | 10:14 AM
Zoomie's Avatar
That is pretty similar to the process I used, and it has worked, albeit in it's own ugly way.
Use duct tape to hold the tear together
Stitch the tear shut
Glue the outside, over the stitching
Pull the duct tape off the inside
Apply a patch inside to eliminate rubbing
Old Mar 6, 2012 | 10:21 AM
darcyw's Avatar
used black silicone adhesive from the autozone and cut the patch from old top material. Took my time to really saturate the patch material. Held so far. I siliconed the patch in place with the vinyl side up and cloth side down(towards the inside of the cabin).
good luck.
darcy
Old Mar 6, 2012 | 12:11 PM
DallasAp1's Avatar
is a patch really neccesary for a rip the size of this circle? " o '
i ordered some loctite vinyl adhesive i planned on just globbed it on and around the hole on the inside.
sadly i noticed my passenger side also has a tear the same size thats just beggining i midaswell start saving for a new top im ready to retire the plastic back window
Old Mar 6, 2012 | 12:35 PM
s2kPA's Avatar
I'm just wondering why "Tear Aid for fabric" if the S2K top is vinyl ?
