Smartire mount
Old Jun 10, 2001 | 12:48 PM
Rick Hesel's Avatar
Former Sponsor
Default Smartire mount
For those who have been asking to see how I've mounted the Smartire tire pressure and temperature monitor, here are a few photos:
The monitor, which reads radio signals sent by sensors in each wheel, is mounted on a hinge under the dash near the driver's side door. Velcro holds it up and out of sight.
When I want to read the tire pressures and tempertures, I just fold the monitor down.
This is a wonderful gadget, but only if peace of mind is worth $300 to you. Since I don't have a spare, I'm obessed with monitoring my tire pressures and this is an essential device in my car.
Old Jun 10, 2001 | 01:53 PM
Eze8199's Avatar
Are there any wires that come out of the smartire monitor? Does it use batteries?
Old Jun 10, 2001 | 02:29 PM
Rick Hesel's Avatar
Former Sponsor
There's a power cable, run into the fuse box to tap a power source, but for all intents and purposes, it's competely out of sight.
Old Jun 10, 2001 | 02:37 PM
Eze8199's Avatar
was it easy to install to the fuse box?
Old Jun 10, 2001 | 04:27 PM
Eze8199's Avatar
Old Jun 10, 2001 | 05:09 PM
Rick Hesel's Avatar
Former Sponsor
This is very easy to do. Radio Shack has inserts you plug into an empty fuse slot along with a fuse. The inserts have a spade connector on them, so you can tap right into the power. It's simple even for a novice. Remember Honda uses the mini slot fuses, not the old-fashioned glass tube type.
Old Jun 10, 2001 | 05:12 PM
Eze8199's Avatar
where is the fuse box located?
Old Jun 10, 2001 | 05:13 PM
shaner's Avatar
Rick,
I will have to post my visor-mounted receiver install... You knew I couldn't put it in an "ordinary" location... didn't you? That would be way too easy
Old Jun 10, 2001 | 11:55 PM
nvmys2k's Avatar
Rick, pretty cool...Your brain is always working, isn't it?
SlowTeg
Apr 24, 2012 04:47 AM
HighTider
Oct 9, 2011 12:20 PM
Assass1n
Jacksonville
13
Aug 1, 2011 05:53 PM
13darkknight
Aug 31, 2010 10:17 AM
sigsegv
Jul 29, 2003 12:39 PM
