Soft top adjustment
Old Feb 21, 2005 | 02:49 PM
jdmdohcpower's Avatar
Default Soft top adjustment
Anyone know who to adjust the top latch so it will make a tighter seal. I can hear wind over the driver side latch and if I press on it just a little bit it seals and the noise goes away.
Old Feb 21, 2005 | 03:13 PM
1a-race's Avatar
Banned
Old Feb 21, 2005 | 03:16 PM
Whats that supposed to mean????????
trich1687's Avatar
The latches that secure the top are worn, this is a known problem on the earlier cars. This is the part on the windshield frame , not the top. Mine were replaced under warrantee. If you look at the striker you will see the metal is worn away where the hook grabs of contacts it. A temp fix is to take a small piece (3/4" long) of rubber hose like 3/16" ID soft vacuum line and slip it over the hook on the top. This takes up the gap and will compress a bit if needed. The wind noise drove me nuts till I did this.
Old Feb 21, 2005 | 03:32 PM
1a-race's Avatar
Banned
it means there is a search bar in the top right hand corner
a simple search of "adjust top" reveals this thread 5 topics down.
https://www.s2ki.com/forums/index.php?showt...6&hl=adjust+top
Old Feb 21, 2005 | 03:49 PM
Thanks, the metal is worn and I guess I will have it replaced under warranty
Old Feb 21, 2005 | 07:34 PM
singlespeedman's Avatar
I slotted the holes on the bracket attached to the top, and then moved them forward until i adjusted it where i liked it. This is what worked for me. May not be suitable for everyone.
Himura357
Mar 28, 2018 10:51 AM
Talent
Oct 20, 2014 01:31 PM
Shopman
Nov 12, 2013 04:45 AM
Peachy
Jan 26, 2013 02:21 PM
