Soft Top Cover - Replacement
Hi all,
I'm looking to get a soft top cover for my 2005 S2K. So far, I've seen two styles: original, OEM style (black, looks plastic-ish, good enough and what I'm leaning toward) and the CR style (looks fiberglass and/or not flexible, much better looking, probably costs more).
Are these the main options for soft-top covers? If so, does anything have any good, affordable recommendations? I'm trying to avoid buying it from Honda for nearly $500.
Thanks!
Thanks!
I meant they have cover like this:
Fixed the link
Sorry, was posting from my phone. i fixed the link.
Fixed the link
The link didn't work. But I think you mean something to cover and hide the softop when its open. Either the optional Honda tonneau cover, or something hard like the roll hoop humps that CR uses (which would not work as a softop cover, in CR they cover empty space).
Your options are:
1. Buy a good, used tonneau for around $150
2. Buy an aftermarket hard cover that simulates CR humps, but os made to.cover open softop.
3. Buy a new tonneau for way too much $, if its even still available.
People hardly ever ise their tonneau, so used ones typically have very little wear.
Your options are:
Received 1,562 Likes
Well I use mine a lot driving locally. In Northern California the weather is nice and the top is down most of the time. The tonneau cover does a good job keeping things clean and eliminating UV damage. Has a clean finished look. On the road is a different story; I leave the cover at home. I use plastic trim tools to help release the pull knobs for removal.
I have not seen the aftermarket hard cover that simulates the CR humps. Anyone with a link?
Your options are:
Your options are:
The roof goes up or down in six (6) seconds. Unless you use the tonneau cover and then it takes six (6) minutes. Once you get it off, say to raise the roof in a sudden rain squall ya gotta store it somewhere. You're standing in the rain all this time. I confirmed mine fit. Only time on the car.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
It looks good...and thats pretty much it. Its very impractical.
If you KNOW its not going to rain, and you won't have to park anywhere for more than a couple of minutes, and...
For as much as we're known for our grey, damp days here in the Pacific Northwest, once summer sets in, pretty much all we see is sunshine for months on end. So for something like the local cars 'n coffee gatherings for example, it's sometimes nice to throw the cover on as I do like the look. But as you've likely gathered by now, many here are not all that fond of these. If you still want to obtain such a cover after reading the above feedback, I'd suggest starting by placing a wanted ad here on s2ki. You could also check the auto parts listings on you local craigslist as people always seem to be getting rid of these things (again, see the reasons listed by some above). While I like mine okay, I wouldn't recommend spending a fortune on one of these covers.
FYI If you do obtain one of these covers and you find it incredibly frustrating to put it on, then you likely need to replace the soft-top straps with a new replacement set (such as those made by Modifry). This will help snug the soft-top down tighter, presenting lower profile, which in turn makes it much easier to put the cover on. (Worn soft-top straps can also be identified by the fact that they have practically no elasticity left in them.)
