soft top wouldn't fold all the way down
Old Nov 23, 2008 | 01:15 PM
dorami's Avatar
Default soft top wouldn't fold all the way down
for those who have added sub woofer carpet at the hinge that tears the soft top, does ur top fold down all the way? i noticed that mine doesn't after adding the carpet onto the hinge. i have to manually push the top while holding the top down button in order to get it all the way down.
Old Nov 23, 2008 | 01:26 PM
Shopman's Avatar
I imagine the stuff you have used is either too thick or too tight.
That picture is of my car when I came up with the fix a couple of years ago and my roof folds just fine.
Old Nov 23, 2008 | 01:30 PM
dorami's Avatar
hey thanks for ur quick reply, i followed all ur steps into doing this. i cut out exactly the size u mentioned and i wrapped it around the straight bar tightly and slowly slide it up to the hinge. how tight did u wrap ur carpet? i think i wrapped mine pretty tightly and i'm sure the material i am using isn't too thick.
Old Nov 23, 2008 | 02:08 PM
Shopman's Avatar
I can only suggest you remove them and see if it cures the folding problem.
If it does revise your design.
The cloth I used is quite thin and stretchy, perhaps yours is a heavier weight or you have wrapped it too tightly. Try it again with a bit more room around the elbow
Old Nov 24, 2008 | 08:33 AM
zoomkat's Avatar
The top clearances are tight an any material added has the potential cause a bind. I used a small thin piece of vinal to reinforce the wear spot, and filed off the rough edge that was cutting the top. I suggest removing your material to see if it fixes the problem. If you don't want to remove your stuff, you might try using some silicone spray lube to make the surfaces slide more easily.
Old Nov 25, 2008 | 05:21 AM
Ks320's Avatar
Actually .. you don't need that subwoofer carpet
That black patch you have on the soft top is sufficient to protect the top ...
Old Nov 25, 2008 | 05:54 AM
Onehots2k's Avatar
Shopman, what method is your avatar performing? I need my coffee
Old Nov 25, 2008 | 06:05 AM
foxy_s2k's Avatar
Heel and toe downshifting, unless I'm very much mistaken.
Old Nov 25, 2008 | 09:55 PM
dorami's Avatar
actually that picture isnt mine. i don't have the black patch and i don't really wanna stick anything to the soft top. i re did the sub woofer carpet this time a bit loose and i think the cold weather might have an effect on it not folding properly. i guess i'll wait till summer and see if theres still a problem. if so i might try a different material.
Raabjorn
Jul 9, 2025 12:31 PM
rudyy
Mar 30, 2017 06:32 PM
Pinky
Mar 20, 2013 07:46 AM
S2KVee
Nov 17, 2011 09:28 AM
Tonky
Mar 7, 2002 04:10 AM
