some help please!?
Old Sep 23, 2002 | 01:31 PM
vin02s2k's Avatar
Default some help please!?
hi all,
i was thinking to change my tranny oil and differential oil tonight but funny thing is that i never done these before... not in my life and tonight is going to be the first time (i only change my engin oil). i don't even know where the drains are. i was just wondering if any of you have some pics that show where the drains are and the filling hole? i'm going to go get some oil now and hopefully i will have bunch pics and tips when i come back because i know you guys are the best when it comes down to helping out other members
Old Sep 23, 2002 | 01:42 PM
vin02s2k's Avatar
BTW i already know what i need and the procedure from the search so all i need is to know where they are located. thanks!!
Old Sep 23, 2002 | 02:01 PM
xviper's Avatar
Sorry, no pics. I shoulda done this one as a "How to" also. But I'll describe it as best I can. The drain plug is the lowest plug on the driver's side (left) and is removed with a metric socket (can't remember the size). The fill plug is on the same side but a bit higher up and forward of the drain plug. It is a "recessed" bolt. That is, you take it off using only the 3/8" drive rachet WITHOUT a socket on it. That's right, it's a square 3/8" hole in the middle of the bolt.
Old Sep 23, 2002 | 03:47 PM
Schatten's Avatar
[QUOTE]Originally posted by xviper
[B]Sorry, no pics.
Old Sep 23, 2002 | 05:00 PM
xviper's Avatar
Originally posted by Schatten
no pictures but its already in the library xviper.
https://www.s2ki.com/article/archive/8/
Thanks, glad you picked up on that.
Old Sep 23, 2002 | 05:09 PM
vin02s2k's Avatar
[B]Sorry, no pics.
Old Sep 23, 2002 | 05:12 PM
Schatten's Avatar
you can't miss it. you'll know when you check it out. seriously. if you have the right tools you know what fits and what doesn't where. but having the correct tools for the diff is essential.
Old Sep 23, 2002 | 05:13 PM
xviper's Avatar
Originally posted by vin02s2k
thanks for the fast replies, i checked the library already and i just need to know the location... now i have it but what about the differential location!? sorry to bother but i just want to make sure before i start it. thanks.
Boy! You're going all out, aren't you?
Diff drain is directly on the bottom of the diff where you jack the car up. It's a 24mm socket. The fill bolt is on the back side of the diff higher up. You need a 23mm closed end wrench to get that one.
For both the fluids, get yourself a pump or a piece of clear tubing and duct tape it to the pointy end of the diff fluid bottle and squeeze it in. Then clean the tube and the pointy end of the diff fluid jug and use it for the tranny fluid jug to squeeze it in too.
Old Sep 23, 2002 | 07:15 PM
vin02s2k's Avatar
xviper & Schatten thank you all for your helps. just changed the tranny fluid and boy what a difference... i only have 8000 miles but after reading all the threads about the GM synchromesh i just couldn't resist for trying that out and it did change the hard shift problem i'm gonna try to change the diff and i think it will be lot easier because i don't think it will be harder than the tranny since it's way back there and it should be easier to get to. well, again thank you all for your helps i really appreciated.
GrandMasterKhan
Nov 5, 2009 05:34 PM
spectacle
Dec 12, 2006 01:25 PM
mm2000
Dec 7, 2004 08:36 PM
UCrazyKid
May 2, 2002 01:39 PM
UCrazyKid
May 2, 2002 09:58 AM
