Spa Yellow is it a clear coat?
Definitely has the clear coat. The S2K gets three trips through the paint booth:
1) Zinc Phosphate + Electrodeposition (i.e. undercoat)
- In the pretreatment process, the entire body is degreased, cleaned and coated with zinc phosphate by dipping. After the body has been cleaned by pure water, it is placed in an electrlyte bath of soluable primer (Cationic Electrodeposition) This produces a thorough corrosion inhibiting coating on the inner surface and corners of the body, pillars, sills, and panel joints. A chipping primer is then put over susceptible areas.
2) Chipping Primer + Intermediate coat
- The intermediate coat is applied to the prepared surface for further protection against damage.
3) Solid Color enamel + Clearcoat or
Metallic Enamel + Clearcoat or
Pearl Enamel + Clearcoat
- Enamel paint and either polyesther or acrylic resin paint are used in the top coat for higher solidity, smootheness, brightness and weather resistance.
Source: Helm 2001 Series Body Repair Manual
rumor has it that the yellow is a 4 step paint color. Something like a coat of white followed by a coat of yellow followed by pearl followed by clear. I don't know if it's true but that's what a buddy was told by the paint shop where he ask to get his CRX in Spa Yellow (BTW, he picked a different color)
Originally posted by Utah S2K
Might want to tell your friend it's a three step process FOR SURE
krazybartender
Aug 21, 2002 03:32 PM
