Spin Out...Has anyone had one?
Originally posted by PanhandlingS2K
Most of your spin was probably attributed to the bald tires. But, you should never try to turn the wheel when hydroplaneing (sp?). If ever again you feel the car begin to hydroplane, just let off the gas slowly and hold the wheel steady, this allows the tires to re-grip once the rubber meets the road again. You will likely feel the tires re-acquire traction and be on your way. Also, going 60mph during just about any steady rainfall in a car with a small wheel well is not a good idea, slow down and get over in the right lane.
Moral to the story........you can spin even if you DON'T turn the wheel if you are travelling too fast and there is too much water on the road.
Originally posted by Mike in Atlanta Moral to the story........you can spin even if you DON'T turn the wheel if you are travelling too fast and there is too much water on the road.
You guys are forgetting that it is rear wheel drive and that is why it is alot easier to spin out. Most of the weight is towards the front of the car causing the rears to be able to come out behind you easier. I know our cars are well balanced but it I still believe this is the case. Driving a fwd vehicle in rain is a piece of cake and makes all the difference. I too have had 2 bad experiences in the rain within the first month that I owned my car and was lucky no one was around. This is the first RWD vehicle I have ever owned. Both times I put more gas then I should of while turning in the rain. One of them was a 360' and I was trying to make a light before it turned red and the second one I was debating on turning and if there was enough time to get across the road in a right hand turn and made a bad decision. And parked it on a curb.
I have said this before, the SO2's are dangerous to the uninformed. Most powerful rear drive vehicles are prone to oversteer but the SO2's create a bigger problem than is necessary on the S2000. Everyone that buys an S2000 can not drive it only when it's dry out. And, no, I haven't spun it (yet).
The Benz is very sure footed on the interstate at 70 mph in a downpour. The same speed under the same conditions in the S2k would be potentially dangerous, especially on tires showing significant wear.
Another difference between the S2k and most other cars is that the S2k has a very low polar moment. Most of the mass is located between the wheels, so the car reacts very quickly. Think of a barbell with the weights on the end, as compared to one with all the weight in the middle. The bar with the weights in the middle will rotate with less force applied to the bar. Same thing is going on with the S2k, so under less than ideal conditions it can get away from the driver more quickly than cars with most of the mass at the front (FWD) or back (RWD mid or rear engine).
RED MX5
Yeah i was lucky enough Not to spin out.... i was having a new set of rears put on and they were showing metal
those 2 weeks before when it rained my car would shake side to side while staying in the lane. I just had the khumo mx's put on with the same size tire width as the so-2s and im very happy with the setup.. So as a warning to any S owners Keep an eye on your rear tread!!! could be the difference of life/ deathof you/ your S!!!
safe driving!!!
thomas
those 2 weeks before when it rained my car would shake side to side while staying in the lane. I just had the khumo mx's put on with the same size tire width as the so-2s and im very happy with the setup.. So as a warning to any S owners Keep an eye on your rear tread!!! could be the difference of life/ deathof you/ your S!!!safe driving!!!
thomas
My new 04 (3800 miles) was riding a bit stiff. I thought maybe that the dealer had left the shipping spring spacer's in my rear springs. I looked and found none. After reading about checking the oil EVERY fill up and checking tire pressure, I decided to check mine. The rear tires were at 37 lbs.... fronts at about 35. I reduced them all to 32 and could instantly feel the difference. The screwed up roads in DC didn't feel quite so bad this morning.
This site is a GREAT resource. Thanks everybody!
I've only spun on the dry race tracks by pushing too hard!
I think we just need to be real smooth that's all. Stay calm, don't try to change lanes, don't try to lift from the gas suddenly(the sudden shifting of weight forward will further help induce a spin)... just do everything gradually whenever you find yourself going too fast under wet conditions. S2k has this snap oversteer problem. Lowering rear tire pressure should also help alleviate this problem a bit.
Just couple of days ago I found myself going too fast going on a wet highway... decent amount of rain, 75mph... I did notice the car started to sway mildly everytime I change lanes... (I think it's because of the lane markers and the higher water build-up around it or something...) my rear tires are balding too..., but I stayed calmed and smooth and slowed down a bit and all is well!
