Spoon duct install questions......
Not sure if this belongs here or under the hood, but here goes:
I did a quick once over of the airbox to see what needs to be done to install my spoon air duct and I came up with a few questions:
1) Any tips on removing the stock opening plenum? There are two screws underneath that are impossible to get at without ripping out the entire airbox assembly.
2) I guess you can call it the radiator cover, or the black plastic piece that shrouds around the hood latch. The directions (in japanese that I can't understand) say to remove the whole thing, but again, crazy impossible screws. Do you guys recommend just cutting away a hole instead?
3) I didn't see any real fasteners with the kit, does it just stick there by itself?
Thanks for the help
Simon
Thanks for the help
Simon
I would recommend using a dremel or very sharp razor to cut out a percise square for the spoon duct. Spend lots of time making it look perfect. people will give you more props for not hacking up your S2K.
Here use this as a guide: (It has great instructions and pics.)
http://forums.s2ki.com/forums/showthread.p...threadid=118787
and this one:
http://forums.s2ki.com/forums/showthread.p...threadid=183292
Hope this helps.
and this one:
Hope this helps.
I jus installed mine and for the two screws i cut them and saved the front peice for when i want to go back to stock. I used xvipers instructions but if you have any questions give me a holla.
