Starting problems
Old Jan 19, 2001 | 02:08 PM
Dorian Gray's Avatar
Hello all.
I have a question regarding starting on a cold morning. Now understand that I live in Vegas and when I mean cold were talking about 35-40 degrees in the morning. Not freezing Anyway, when I start the car up in the morning it dies out after a couple of seconds, I can keep it from dying out by stepping on the gas but won't this hurt the engine in the long run?. It only happens when the car has been sitting overnight.
George
Black/Black 2001 895miles
Old Jan 19, 2001 | 05:57 PM
wirejock's Avatar
[green]You're probably ok as long as you don't rev it up before the oil heats up. If it's still under warranty I'd have the dealer check it out.[/green]
Old Jan 19, 2001 | 11:33 PM
hondas2200's Avatar
It may be the oil 10w30. I experienced a slow start with my s2000 when i had to park it out in the cold (20F) for hours.
Old Jan 20, 2001 | 12:16 AM
lvs2k's Avatar
You're probably going to have to park it at your dealer outside overnight in order to replicate the problem. Mine has set out in sub-freezing weather for several hours and I have never experienced a similar problem. Good luck.
Old Jan 20, 2001 | 06:51 AM
jguerdat's Avatar
Originally posted by Dorian Gray
Hello all.
Not to worry. I live in much colder temperatures and can't drive mine every week, not to mention every day. Cold starts were a bit of a problem when new - it wanted to chug until I blipped the throttle. The computer probably has a "training" sequence - notes probelms when starting and makes minor modifications until it works properly. My cold starts after 800 miles or so are flawless, even after sitting for a week or two in 10-30 degree F temperatures...
JKN
Dec 1, 2007 01:22 PM
Dolemike
Nov 18, 2005 06:42 AM
REVS 9K
Jan 20, 2005 10:13 AM
zdave87
Jun 23, 2004 07:03 PM
Argetni
May 24, 2002 01:22 PM
