Sticky clutch pedal
Old Oct 12, 2024 | 10:30 AM
DarkHorse2K1's Avatar
Default Sticky clutch pedal
Hi everyone,
as title says, my clutch pedal suddently felt harder to press and sticked to the floor a bit when driving the car. The clutch SHOULD only have 10000km, and i have a leaking clutch master cylinder that i have to replace. Could it be the problem? The CMC is leaking from some time but this happened only today.
Old Oct 12, 2024 | 02:52 PM
B serious's Avatar
What kind of clutch was installed? And what type of grease was used for the sliding surfaces? Also, was the release bearing guide replaced?
Yes, a leaky master cylinder will cause your issue if there was enough fluid loss. Check your clutch fluid level.
Old Oct 12, 2024 | 03:03 PM
The clutch should be OEM, don't know about the grease, don't think the guide has been replaced (the clutch was replaced by previous owner so i have limited info). The fluid has just been replaced and it's full.
Old Oct 13, 2024 | 12:11 AM
Today i took the car out and i noticed that it makes a noise (like something that's not greased/lubed) in the last part of the pedal travel
supraken
Jul 24, 2017 08:41 PM
alanpikku
Apr 7, 2012 08:00 PM
FormerH22a4
Sep 29, 2007 11:23 AM
blacks2k
20
Mar 6, 2007 08:44 PM
vteconly
Sep 1, 2006 10:02 AM
