Stock Clutch Adjustability?
So i know in many manual transmission applications clutches can be adjusted...I.E.:the time or distance it takes for the clutch to engage. I have an '01 S. Does this adjustability exist in the stock form of this vehicle?
Don't always take "many" clutches as being applicable to an S2000. Most other clutches are cable operated. Ours is hydraulic. Nevertheless, it can be adjusted slightly but it is not wise to mess with it unless you have a specific reason to do so. And having something wrong with the clutch system is not reason enough to change the "adjustment". It's better to fix the problem than to adjust it away.
Having stated this, here is the info you want:
https://www.s2ki.com/forums/index.php?showt...0&#entry5234269
