Strange gear noise
Old Sep 4, 2003 | 08:16 AM
ADAM_ROB_UK's Avatar
Default Strange gear noise
When ever I am in 3rd 4th 5th or 6th.... I hear this high pitch whine from my gears at about 3-4k rpm.... It is happening allot now....
IM not sure where it is coming from but it seems to be getting a bit louder
thanks in advance for any help
Old Sep 4, 2003 | 08:23 AM
sebrings2k's Avatar
Due to the close proximity of the tranny and the cabin your just hearing all the mechanical stuff going on.
I hear a good amount of gear whine myself.
By the way do you hear it more when you deccelerate/let of the gas vs. taking off and accelerating?
Old Sep 4, 2003 | 08:57 AM
3ngin33r1's Avatar
[QUOTE]Originally posted by ADAM_ROB_UK
[B]When ever I am in 3rd 4th 5th or 6th.... I hear this high pitch whine from my gears at about 3-4k rpm.... It is happening allot now....
Old Sep 4, 2003 | 09:23 AM
Hey guys thanks for your quick replies.
Well I really hear the gear whine when I am cruising at a steady speed.. Keeping the rpm between 3-4k
[QUOTE]3ngin33r1
Old Sep 4, 2003 | 09:50 AM
xviper's Avatar
Gear whine is usually (but not always) associated with rear diff issues. The whine should increase intensity with road speed. rpm should have little to do with it. If indeed, it is the rear diff, once you make the whine, push in the clutch, put in neutral and coast. Does it still whine? If it does, you may have just confirmed it. Have you had rear end work done lately? Try changing the diff fluid. This fluid change is WAY TOO under-rated by the owner's manual. I think it should be done after a few thousand miles and then annually.
Old Sep 4, 2003 | 10:01 AM
WRS2K's Avatar
xviper,
Could Honda be that insular re: diff oil change interval?
Does anyone know what the factory diff oil looks like when new?
Old Sep 4, 2003 | 10:14 AM
xviper's Avatar
Originally posted by WRS2K
xviper,
Well, I feel that I should have changed mine out early. Those first few thousand miles are the worst on any new set of gears. When I changed mine out at the prescribed 1 year time frame, the fluid and the magnetic plug was THE filthiest and most grunged up of any of my subsequent changes. Now, whether or not such filthy fluid is a detriment to the diff is another story. Some say that it really doesn't matter how dirty that fluid is. I just didn't like the amount of "fuzzing" on that drain plug at the first change.
I also noted after my 4.44 gear swap, when I changed that fluid out after about a 1000 miles, it had some significantly larger metallic particles stuck to the plug. I don't know if this is a negative sign since the plug did its job, but with all the "so-called" reported "weak" diff issues, I'm happier in the knowledge that the diff fluid gets an early change the first time.
Old Sep 5, 2003 | 12:31 AM
Thanks Xviper I will have to try that when I am out this weekend. I have not changed the rear diff oil and I have done about 3k miles. It is an 02 Honda that was imported from Holland (to save money(and I saved about
Old Sep 5, 2003 | 06:34 AM
xviper's Avatar
[B]Thanks Xviper
JimAp1
Sep 29, 2019 12:07 PM
blackv3ngenc
Sep 9, 2014 09:54 AM
TrboLag
Jul 22, 2010 09:45 AM
blitz16v
Oct 16, 2007 07:03 AM
Muz
63
Nov 13, 2002 10:25 PM
