Strap Buzz
Old Jul 17, 2004 | 09:27 AM
Homo Sapien's Avatar
Default Strap Buzz
Bought car in March - never (NEVER) drive with top up so toneau cover is on virtually 100% of the time. So I'm driving up Route 208 and I hear this buzzing sound. Slow down and it goes away. I'm reaching all over to see what I can touch to stop the sound - mesh in passenger headrest? passenger seat belt?
Finally figure out it's the passenger side strap for the toneau cover. So I put a rubber grommet on it - a grommet normally used for an electrical junction box to prevent frayed insulation. This seems to have solved the problem
Has anyone else dealt with this?
Old Jul 17, 2004 | 11:31 AM
Ludedude's Avatar
Administrator
Yep, just twist the elastic strap once before attaching it. Problem solved. You'll probably only notice this noise without a passenger in the car. It's a weird aero thing that doesn't happen when there's a body there to change the airflow.
Best solution? Get a companion
Old Jul 17, 2004 | 01:34 PM
amartin's Avatar
^-- agreed.. give it 1 full turn before clipping on the elastic band.. I've been doing that for years now to my S2K's... problem is solved..and its not noticible..the twist I mean.
Old Jul 17, 2004 | 06:53 PM
I didn't want to stretch the strap long term so avoided the twist thing - but yes that works.
Got the companion, then created three more companions, then original companion wanted a dog, so now I sometimes need to drive around companionless.
Thanks for the advice.
Old Jul 17, 2004 | 07:28 PM
Smokee's Avatar
^ You have completed the circle. Funny stuff.
Old Jul 17, 2004 | 08:41 PM
Nicotunes's Avatar
Silly question: Is the cover really needed? Have yet to use it....should I? Thanks.
Old Jul 17, 2004 | 09:27 PM
Smokee's Avatar
I use mine because:
Looks good
Keeps dirt and crap off your top
Keeps the sun off your vinyl top, sun . . . bad
I don't use it if I know I'm going to be putting the top up and down a lot though, such as around town. On long drives, always.
Most people don't use it and a lot say it's a PITA. Takes me about a minute to put it on and off.
Old Jul 17, 2004 | 09:59 PM
wickerbill's Avatar
It doesn't stretch the strap that much at all so I wouldn't worry about it messing it up permanently.
Old Jul 17, 2004 | 11:53 PM
Saud2k's Avatar
wow thanks guys i have been having this problem for a long time now
Old Jul 18, 2004 | 06:50 AM
slalom44's Avatar
Top Answer: 1
Last year, someone posted a solution that I use. If you unscrew the snap on the elastic strap and screw it back on backwards (facing the opposite direction), then you have to twist the strap 1/2 turn to snap it on. This way, you don't have to twist the strap as much and you can't snap it on in a way that will make it buzz.
It works like a charm, and takes less than 5 minutes to do!
MrM
Nov 17, 2008 11:59 AM
scotchtape
Sep 20, 2004 11:46 AM
Jason B
Jul 23, 2002 05:36 PM
tripod
Jun 21, 2001 01:50 PM
socal28
Mar 23, 2001 09:14 AM
