Street/Auto X alignment specs HELP!
Old Jul 15, 2021 | 04:49 PM
BobS2000's Avatar
Default Street/Auto X alignment specs HELP!
Can anyone here recommend good alignment settings for street/ auto cross for a 04 S2000. The car has a .250 karcepts front sway bar, Ohlin's dfv coil overs 12k front 10k rear and 255/40/17 all around.
Thanks,
Bob
Old Jul 15, 2021 | 05:34 PM
darcyw's Avatar
I have the front bar on 3 holes from soft on one side, 2 holes from soft on the other side. Maximum negative camber that can be achieved on OEM components. Can't recall the toe off hand, sorry.
darcy
Old Jul 16, 2021 | 06:27 AM
engifineer's Avatar
For a very long time (mainly because I never installed adjustable ball joints up front) I ran the following and it worked pretty well. Car is lowered about 1 inch
Front Camber: -2.6 degrees (maxed out)
Zero front toe
Caster 6.9 degrees
Rear camber -2.6 degrees
Zero rear toe
Moddiction bar on full stiff
I recently made some changes and went to a Kacepts front bar. I mainly use the s2k for track nights (normally on a pretty tight, short course) and a little autox these days since I have a codrive for autox in a different car. But the changes up front with having adjustable balljoints allowed more camber and the car feels better this way.
Front camber: -3.5 degrees
Front toe: 0
Caster: 7.8 degrees (more on this in a moment lol)
Rear camber: -2.8 degrees
Rear toe: 0
Karcepts front bar set on 2 out of 6 and stock rear bar
On the caster, normally I did not expect to get much over 7 so told my alignment guy "max caster". Did not expect to get 7.8 degrees . However, I have been driving it and attended a track night and it is not bad and of course gives more dynamic camber. But I likely will dial it back down to the low 7's. It does change steering feel quite a bit. But again, it worked pretty well at the last track night and for driving around, you notice the extra weight on the steering but not terribly.
Old Jul 17, 2021 | 07:40 AM
Hyperdrive's Avatar
Zero front toe
Caster 6.9 degrees
Zero rear toe
Front toe: 0
Rear toe: 0
Do you change the Karcepts front settings when you go to track and autocross? Or you just find the right setting and stick with it?
Sexi2k
Mar 11, 2015 03:32 AM
tbp5022
Jun 1, 2012 07:54 AM
Mr Ak
Jan 18, 2010 08:11 AM
Nole99
Jul 19, 2005 05:29 PM
