STUCK IN MIDDLE OF INSTALL
Old May 15, 2007 | 09:26 PM
Saki GT's Avatar
Where did you get this plate from anyway? AUT?
Old May 15, 2007 | 09:33 PM
nightcrawler7188's Avatar
i bought it from an s2ki user named "sparrow" at about 9pm tonight. he told me it was authentic AUT and had the receipt, etc. to prove it. it fits either way.
its cool, i got it to work--THANK YOU SO MUCH TO THOSE OF YOU WHO HELPED ME SO EARLY IN THE MORNING!
i just hope that i'm not jacking up my hood by having to drop it from 3 feet every time!
ok i know i'll do it myself for you guys:
Old May 15, 2007 | 11:00 PM
Project22a's Avatar
You didn't put that long metal plate back in did you?
Old May 16, 2007 | 05:04 AM
Dave-ROR's Avatar
That's my guess too...
Old May 16, 2007 | 10:51 AM
no i didn't put it back in. i read an s2ki member's DIY before i started.
Old May 16, 2007 | 11:20 AM
Saki GT's Avatar
Fwiw, I've seen people install it with the cooling plate without problems.
Old May 17, 2007 | 05:20 AM
NFRs2000NYC's Avatar
Ive said it before, and Ill yell it again..
THE S2000 HOOD, AND ALL ALUMINUM HOODS ARE NOT SUPPOSED TO BE PRESSED CLOSED! THEY ARE MEANT AND CONSTRUCTED TO BE DROPPED!
Old May 17, 2007 | 06:05 AM
Saki GT's Avatar
3 feet? While you should drop the hood to close it, anything over 8"-12" is excessive - maybe try tightening the bump stops a half turn and see if the helps?
Old May 17, 2007 | 09:26 AM
Boofster's Avatar
The AUT is a pain in the ass but you can't expect it to fit perfect. I had to spend a good 2 hours dremeling out various spots where it just didn't match up. At first, the middle hinge was touching so it offset the whole plate. Then as the poster said, one of the bolts wouldn't quite match the hole so it had to be enlarged.
So put it on, mark, remove and dremel. Clean it up then repeat until everything matches up.
Old May 17, 2007 | 10:35 AM
FitzyS2k's Avatar
i would also raise the hood latch. loosen the screws and raise it up and retighten.
