STUCK IN MIDDLE OF INSTALL
Old May 15, 2007 | 08:22 PM
nightcrawler7188's Avatar
Default STUCK IN MIDDLE OF INSTALL
HELP PLEASE--NOW IF POSSIBLE
i lost one of the 5 bolts that holds down the cooling plate over the hood seal in the front of the engine bay, but there's 4 others and i'm sure it won't be a problem. but, i can't get the LAST bolt in--the one holding down the radiator hanger on the side opposite where the airbox inlet is. what should i do? i'm assuming it's NOT a good idea to leave this one out, but i think the screw is JUST short enough so that i can't get it to go in.
Old May 15, 2007 | 08:29 PM
Saki GT's Avatar
Push down harder? Why isn't the plate sitting flush? Try screwing the two radiator screws back on first, then the front plates?
Old May 15, 2007 | 08:55 PM
yea i think that'll help
thanks AGAIN Saki
Old May 15, 2007 | 09:02 PM
Saki GT's Avatar
Don't fully tighten everything until all the screws are seated in their holes, then you can see if there's a fitment issue or finish up.
Old May 15, 2007 | 09:10 PM
ok IT ALL FIT. now the hood isn't closing. even if i give it a love push, it isn't staying down. i did it once, now it's just popping back up every time.
Old May 15, 2007 | 09:15 PM
Empedocles99's Avatar
I had the same problem, you just have to slam it shut every time from about 6-12".
Old May 15, 2007 | 09:17 PM
im scared, but will try it now.
Old May 15, 2007 | 09:18 PM
it's not working!
Old May 15, 2007 | 09:22 PM
is there any other way to get this hood closed?
Old May 15, 2007 | 09:23 PM
thetz99's Avatar
There are rubber spacers next to the radiator stays and by the shock towers you can lower by tightening them down. If you still have an issue, you will have to adjust the latch.
