suspension...
Old Jun 29, 2006 | 08:43 PM
jbell's Avatar
Banned
Default suspension...
quick question.
i wanna drop the car.. just to even out wheel gap. maybe 1.5"
whats the best solution, that WILL NOT compromise ride quality, or handling?
Old Jun 30, 2006 | 05:32 AM
vtec9's Avatar
Originally Posted by jbell,Jun 30 2006, 12:43 AM
quick question.
how much are you willing to spend?
Old Jun 30, 2006 | 05:41 AM
ForNgoods's Avatar
first question you should ask yourself before your willing to do anything to your car
Old Jun 30, 2006 | 06:19 AM
jbell's Avatar
Banned
cheaper is better bc it saves money for go-fast goodies.
Old Jun 30, 2006 | 06:28 AM
vtec9's Avatar
cheap + suspension don't go well together. The least inexpensive setup that I would ever recommend would be a ground control coilover setup on koni yellows. This will run you around $1000. This isn't that much when you consider you could easily spend $10k on a coilover setup
Old Jun 30, 2006 | 06:37 AM
glagola1's Avatar
There is no suspension set up that will lower the car and provide stock handling and stock ride quality. Period.
With 1.5" drop you will be scraping the front of the car often and you will be scraping the inside of your fender wells with the front tires. If this doesn't bother you, go for it. I personally think it sucks.
The Koni/ground control setup is probably the best for the money but I would only do a drop of .75" personally.
I had koni's and they have less compression dampening than stock. This means on the big hits the front of the car would often scrape. I dont know, maybe the stiffer ground control springs would help this.
Old Jun 30, 2006 | 07:06 AM
Ek9's Avatar
Ek9
Banned
The KW3 uses 515 lb/in front and rear, If I was going Koni and GC's I think I'd start there, 500 lbs/in front and back.
"I had koni's and they have less compression dampening than stock. This means on the big hits the front of the car would often scrape. I dont know, maybe the stiffer ground control springs would help this.".
You had them cranked all the way stiff?
When lowering what other issues arise? I saw comments about putting spacers on the rear driveshafts.
Old Jun 30, 2006 | 08:14 AM
vtec9's Avatar
lowered roll center, increased bumpsteer.. the fixes out for these are more like a band-aid. the rear axle spacers are meant to restore the horizontal axel geometry to stock and remove stress on the CV, bushings, axels, etc. They arn't worth the money IMO.. this will be my stance until someone thats lowered can empirically prove something failed because the axles were stressed.
Old Jun 30, 2006 | 01:47 PM
jbell's Avatar
Banned
my whole worry is bounciness. scraping is going to happen no matter what.
i dont want to be bouncing all over the place
i had omnipower coilovers o my del sol, and it was STIFF.
Old Jun 30, 2006 | 01:53 PM
r_duff's Avatar
Dont listen to them. im lowered on neuspeed springs on stock shocks. i canyon and tracked the car. lowered on 18'' volks. no problems at all. same as stock feel, just lower.
PS. they will be for sale soon
