sway bars
Old May 17, 2004 | 03:35 AM
Elizer's Avatar
Default sway bars
in another post by douge, tenblade responded by saying to get either a front sway or an xbrace.
wouldn't it affect the handly characteristics if u only get the front?
would it benefit to get both the rear and front?
Old May 17, 2004 | 04:17 AM
BBY2KS2K's Avatar
The S2000 already has a rear cross brace if this is what you mean by sway bar. There are aftermarket rear braces available but the only benefit is maybe lighter weight and the "bling" factor. Having just the front X-brace and no aftermarket braces for the rear should have no adverse affect on handling.
Old May 17, 2004 | 04:28 AM
Elizer's Avatar
no i have a spoon tie bar i no it does absolutely nothing, but i meant sway bars...
Old May 17, 2004 | 04:43 AM
steven975's Avatar
yes, sway bars tie to each control arm and transfer force from one to the other. Getting a thicker front bar will cut roll a little more up front, but also help the front tires break earlier, therefore restoring balance to neutral.
Old May 17, 2004 | 06:39 AM
Z06-KILLR's Avatar
it depends what your uses of the car will be...for autox purposes, if you are going to go with the 225/245 setup, you WILL need a thicker front bar...no excuses.
Nickfromny
Mar 30, 2009 10:45 AM
scirocco25
Jul 21, 2008 05:23 PM
esmith
Aug 31, 2007 09:47 PM
IDGHW
Apr 26, 2007 10:23 PM
FRFR
33
Jan 11, 2005 04:19 PM
