Sweat
Old Oct 31, 2003 | 06:21 AM
WireGuy's Avatar
Default Sweat
I find myself wiping my hands off because of them sweating while cruising in the S2k. This I find odd because I didn't have this problem with my Prelude and they both have leather stearing wheels. Any thoughts?
Old Oct 31, 2003 | 06:24 AM
RazorV3's Avatar
make sure you wash your hands before you drive the s2000. the natural oils and grease(from the foods you eat) can get on the leather and make it fade out. i make it a habit to wash my hands and my steering wheel looks like brand new and i never had the problem with my hands 'sweating'.
Old Oct 31, 2003 | 06:28 AM
Jason B's Avatar
Sounds like an addiction to the 9,000 rpm redline! I often turn the radio off just to listen to the car.
The car feels like it was made for you. You are part of the car when driving it 100%. It's so planted to the road, you just point and shoot and you can take just about anything.
Every time I've owned a car, I get sucked into wanting something else next.
It's weird though, I really am having trouble finding a car that I'd enjoy more. I drove the 350Z, and wouldn't want one. To me it looked much better in pictures than in person. Also as I've said many times before, I didn't get that big grin on my face when driving like I do in the S2k. I just can't stand an engine that sounds like a dead horse under hard throttle.
The S2000 is a ragtop designed for people who drive like "escaped mental patients." If you need storage for more than golf clubs or a pair of backpacks I'd get the 350Z/RX8, etc. If you want to drive fast and have fun doing it, buy the S2000.
_______________________
Some new ownerrs may enjoy reading the follwing about the S2000:
Designed by the same engineers who designed the Championship winning (6 times in 9 years) F1 engines for such greats as Prost, Piquet, and Senna.
Designed by the same engineers who designed the Accura NSX
Hand assembled in the same factory (HONDA's Premier Tochigi Plant) as the NSX.
Limited Production.
Only Front Engined Rear Wheel drive Honda Roadster available since the S800.
Has been on Car & Drivers 10 best list for both model years.
Named to Road & Track's Best both model years
The Engine has been named by Wards as one of the 10 best both years of production.
Has a perfect reliability score in Consumer Reports as well as rated as a best buy and named most fun to drive.
Is consistently compared to cars that cost upwards of $20,000 more and beats them.
The Car
SUPER rigid high center backbone X Frame design. Derived from a Colin Chapman design (Lotus). Is as rigid as many coupes. This allows a stiffer more highly tuned suspension without the worry of chassis flex.
Four wheel double wishbone suspension which is derived from the NSX design.
Showa gas Shocks with the rears having a remote resevoir.
Four wheel disc brakes with ABS.
Special design Brigestone S02 tires.
Electric boosted power steering.
Integrated roll bars both behind the passenger compartment and in the windshield frame.
Excellent crash worthiness.
Recaro Seats.
Alloy pedals perfectly placed for Heel/Toe shifting
50-50 weight distribution. The S2000 is really a mid engine design with the engine mounted in front of the driver but behind the front axle.
Dual airbags.
High Intensity Discharge (HID) Headlights.
Big Red Starter Button!
All controls within fingertip reach of the Steering Wheel.
A minimalist design geared towards giving the driver the closest thing to experiencing a Formula type single seat race car for the street.
The Engine and Running Gear
The highest specific HP per liter, naturally aspirated production piston automobile engine in the world. 120HP/liter.
The highest revving production piston engine (car) in the world. 9000RPMs
Quite possibly the best engine size & weight per HP ratio of any naturally aspirated piston production engine.
With all this performance it is still rated as an LEV
VTEC on both intake and exhaust.
Forged pistons
Forged Rods
Forged crank
Hollow Cams (for lightness and oil flow to the valve springs)
Valve springs and main bearing material derived from the championship winning CART Engines.
Roller valve train
carbon fiber/metalic ceramic cylinder liners.
Chain/gear driven cams
Split cam gears for zero backlash and low noise
Hand welded and formed stainless headers
Nutless rod design
Girdled main bearing carrier with cast iron inserts.
Tapered wristpins for light weight
No ballance shafts
Individual Coils for each cylinder
Die cast aluminum block
Die cast finned aluminum oil pan
Die cast finned aluminum Transmission case
Die cast finned aluminum differential housing
Torsen (torque sensing) LSD
Pressure fed oil circulation in transmission
Just about the best shifting 6 speed ever made.
Ferrari-like RED Valve Cover.
HONDA RELIABILITY AND BUILD QUALITY
Performance
0-60 in under 6 seconds
1/4 Mile in under 14 seconds
60-0 in under 115 feet
Slalom at over 70 MPH
Skid Pad over .9 G
Info obtained by s2ki user "BIEG"
Old Oct 31, 2003 | 09:00 AM
DeluxeS2k's Avatar
getting excited wh ile driving your s2k. isn't this normal?
Old Oct 31, 2003 | 09:33 AM
honda606's Avatar
Adrenaline.
The S2000 is the only car that I have driven that has made me sweat as well.
2KS2000
Apr 14, 2008 02:26 PM
S2KxPhiLe
Oct 25, 2007 07:39 AM
Ocean23ek
Apr 30, 2007 05:23 AM
Superfly05
Nov 29, 2005 01:40 PM
Need4spd28
May 25, 2004 02:06 PM
