Tein hood damper problem
Old May 3, 2005 | 08:45 AM
NFRs2000NYC's Avatar
Default Tein hood damper problem
Whats up guys. Ive just bought a set of tein hood dampers, and have a little bit of a pickle. The ball/bolt that goes into the fender broke in half, separating the threads from the ball. I got the threads out of the fender, but now cant put that damper in. Does anyones know where I can purchase another one of those bolts??? Thanks for the help!
Old May 3, 2005 | 08:50 AM
thetz99's Avatar
What happened to break the head off the shaft of the bolt? I love mine but I would like to know so I don't do it.
Try Jb Weld on the broken bolt/head if you can't find the replacement.
Old May 3, 2005 | 08:51 AM
FF2Skip's Avatar
Bottom half of the page :
GB thread and response to broken bolts
Old May 3, 2005 | 09:51 AM
Thanks!
Yea, I overtorqued them. Use your fingers, and not a ratchet.
Old May 3, 2005 | 01:06 PM
Muz's Avatar
Muz
Former Sponsor
I don't understand how hood dampers can be a good thing when used on an aluminium bonnet that's meant to be 'dropped' shut. Do you have to push down on the bonnet to latch it?
Old May 3, 2005 | 01:08 PM
ruexp67's Avatar
No, it can be dropped from 8"-10" or so.
Old May 3, 2005 | 01:28 PM
Old May 3, 2005 | 01:32 PM
S2kracka's Avatar
Check the GB thread, they posted a demonstration video.
Old May 3, 2005 | 02:03 PM
Silver_S2000's Avatar
Well that sucks....There 125 dollars down the drain...Sorry to hear about this.
Old May 3, 2005 | 02:28 PM
AusS2000's Avatar
When the bonnet is low the dampers are pushing it back more than up so you can still drop it and it will close. It's only when it get above about 30 degrees that the dampers are at the right angle to hold the hood.
