Test Pipe Noise
Old Jun 14, 2005 | 08:06 PM
TriaXenginE's Avatar
Default Test Pipe Noise
Ok, so I had my test pipe put on today and it made my exhaust even louder and I like it very much when i get on the car.
But.........when I'm around 5800-6400 RPMs and i let go of the gas, I hear this RICEY ass noise. This tin-can, rattlely, crap. When i step on the gas, it goes away.
I had Mike(Jacko) drive the car and it sounded alright from outside, but when i'm inside, I can't help but hear this god-awful noise when i'm in this particular RPM range and when i let off. Anyone else experience this?
By the way, it's a T1R test pipe, mated to a J's racing N1 single.
Thanks.
Old Jun 15, 2005 | 12:10 AM
AJ PwR's Avatar
Thanks.
Does the J's Racing N1 exhaust come with any resonator ? Most of the aftermarket exhausts which doesn't come with a resonator, most of them will sounded "buzz" under accleration and deceleration at a certain rpm because it doesnt have enough resonance in the exhaust.
Old Jun 15, 2005 | 12:19 AM
Planets's Avatar
You should check the connections on the test pipe, one of the nuts could be loose.
Old Jun 15, 2005 | 05:21 AM
Yes, it's resonated.
Old Jun 15, 2005 | 07:31 AM
efthimios's Avatar
could def just be a rattle....i had the same issue awhile back and it was indeed a rattle
Old Jun 15, 2005 | 11:46 AM
bkw's Avatar
bkw
It's broken, please remove the entire assembly and bring it to my house for disposal.
Old Jun 15, 2005 | 09:04 PM
LOL
Ya, i didn't get to check the thing if it's got a loose nut. I know the car's got one behind the wheel though.
Anyway, I heard the car from the outside again today. But, when I drive it, this weird noise is killing me.
The set up sounds familiar to the Amuse R1000, only louder.
Old Jun 15, 2005 | 09:22 PM
Planets's Avatar
If the car is still running right I would bet you have a loose nut on the test pipe (as well as behind the steering wheel lol)... I had the same thing happen when I was running a test pipe on my eclipse, one of the nuts worked its way loose and it was the most annoying sound ever, and just like you say, it was on deceleration only and only happened within a certain rpm range
Old Jun 15, 2005 | 09:27 PM
i see. thanks for the info.
bgioan
Dec 3, 2014 01:30 PM
BowlofRice
Jun 5, 2011 04:45 PM
K.Shift
Oct 2, 2010 06:29 PM
viets2k
Aug 30, 2006 10:41 AM
Oz2
Mar 18, 2003 04:14 AM
