Test pipes
Get the Megan;resonator is no big deal,it's a straight pipe,and has threaded nipple for the O2 sensor.
All you need,is a set of anti-foulers,on the O2 sensor,and no CEL on.
$98.00 from Import Tuning,Gary.Love mine.!!!
Originally Posted by Irace4Kimchi,Sep 23 2005, 01:28 PM
do u still have check engine light on w/ this set up?
i want to get testpipe too, but i dont want check engine lights on
3 cars here in Hampton Roads are running it - not a single one of us have thrown a CEL
Ohh - just for answering purposes. All three of us are using a JIC Test Pipe. A bit more expensive, but happy with it !
Originally Posted by Black Nugget,Sep 23 2005, 09:38 AM
Spark Plug Fouler Trick
so is there different size for it?
if there is what size do i need?
Originally Posted by Irace4Kimchi,Sep 23 2005, 02:00 PM
cool
Then install is rather simple.
However, the o2 sensor wire does have some clips holding it in place. All I did was remove the clips so that way I can twist it counter-clockwise. That way when i twist the o2 sensor & spark plug fouler clockwise into the test pipe the wire is straight and not twisted up.
if that makes sense
Originally Posted by Black Nugget,Sep 23 2005, 10:10 AM
You need the 18mm piece. Go to your local Autozone, Pepboys, Advanced Auto Parts - whatever you have in your area and ask them to point you to the "HELP PRODUCTS" isle. Just look for the 18mm Spark Plug Foulers!
if that makes sense
if that makes sense
Thanks!
Originally Posted by Shift_S2K,Sep 23 2005, 12:49 PM
Hey, does anyone know if you need a new donut when installing a test pipe?
