Thicker Head Gaskets with Higher Boost levels Questions
Old Aug 19, 2003 | 07:30 PM
Honda-S2000VTec's Avatar
Default Thicker Head Gaskets with Higher Boost levels Questions
I am looking for advice on what sized head gasket I should put on since I will be trying to reach higher boost levels. I hear people a using 7.5-8 lbs without intercoolers or aftercoolers. I am putting on a Comptech super charger aftercooler and will be shooting for 9-10 lbs of boost. I am thinking about putting on a 1.5mm thick gasket. I read about someone else was turbo boosting 8 plus and and using a 3mm thick head gasket. I am not sure where people are getting high quality head gaskets and what thickness is appropriate? I hear that by lowering the compresstion will comprimise lowend torque to gain high end boost and power. What is the hot setup?
Old Aug 19, 2003 | 09:16 PM
F20c1 & E36's Avatar
If you use a thicker head gasket I believe you will make the motor weaker. Because it make the cylinder quench area weaker. Also a thicker head gasket might give it more area for detonation which might blow out. Correct me if I'm wrong.
Old Aug 20, 2003 | 07:09 AM
Big Ben's Avatar
A thicker head gasket to lower compression has been experimented with a lot by lots of people. About 90% of the time, it fails and the head gasket leaks. It is entirely possible, but not very probable. Don't try it unless you have years of motor building experience with a bonafide race team. It's not worth it.
Old Aug 20, 2003 | 10:08 AM
GChambers's Avatar
Banned
The gasket is the weakest link in the seal between the cylinder head and the block. Why make that space bigger? You are begging for a failure.
f20kills
Sep 12, 2017 07:00 AM
teddy11
Feb 26, 2009 01:42 PM
20vmini
Jan 17, 2005 06:02 AM
SuzukaS2K
May 16, 2003 10:00 AM
Elements
Feb 17, 2003 07:50 PM
