inlinepro head gasket
do u knnow anything about cars lowering the compression if u want to run more boost is smart john lee from in line pro has a 3mm headgasket and he just put down 521 to the wheels and i am doing the gasket as we speek to my car.
you want to lower compression if you want to boost at a high psi..... the inline kit comes with a 3mm head gasket...
and getting a thicker head gasket will make a difference on your potential boost level....
Yes, I know FI cars like lower boost (when you do it the half-ass'd way), but a head gasket ain't gonna make that much of a difference. And if you think you'll be at 521whp because you use the same head gasket, you'll be in for quite a surprise.
Oh, and just for the record, I'm at 548whp, 507wtq on 93 pump. No boost. No spray.
Originally Posted by alexf20c,Jan 16 2005, 12:54 PM
Learn to speak English, and type it as well, before you try and talk down to me.
http://www.srtforums.com/forums/showthread.php?t=100452
but that can't be numbers from your S...
