For those with the spoon snorkle......
Old May 26, 2004 | 04:44 PM
  #21
simons2k's Avatar
[QUOTE]Originally posted by efthimios
Old May 26, 2004 | 04:59 PM
  #22
reds2's Avatar
You can also pick up a radiator plate from ebay and cut it yourself. The quality is pretty good. I haven't cut mine yet, but daveys2k has.
Old May 26, 2004 | 05:23 PM
  #23
Stealth Operator's Avatar
The Spoon intake + Spoon airfilter combo is perfect if you're truly running a N1 race that limits what you can modify but this isn't Japan. Otherwise it's much like a stock airbox design with better airflow, period. This isn't going to increase your heartbeat or make you feel a dramatic improvement but it most certainly does the job better than an OEM setup. Note though, you still carry excessive weight from the OEM airbox and the Spoon intake/filters are quite expensive. Or you can settle for knockoffs.
http://forums.s2ki.com/forums/showthread.p...threadid=190947
Old May 27, 2004 | 02:22 PM
  #24
simons2k's Avatar
Here's a picture of the cf rad plate:
The weave is a little different.
Old May 27, 2004 | 05:27 PM
  #25
tesseract's Avatar
I went with a used Comptech. Sometimes I agree that it looks a little silly, but who cares? I didn't buy this car for show that no one can see...
I am using an AFE filter which has (seems to have) better flow than the old foam filter that came with the intake (i am the third owner..). It sounds a little more 'raw' than stock, which I like, but it can drone a bit when cruising. They are both great intakes, but neither will give much of a gain. Look for the best deal pricewise if you can't make up your mind. Can't really go wrong.
Old May 27, 2004 | 06:42 PM
  #26
Mr. Francesco's Avatar
http://gallery.s2ki.com/imagecatalog/image...eview/149416/6/
howcome the apr radiator cover doesnt require the use of the weather stripping for the hood?
Old May 27, 2004 | 09:48 PM
  #27
reds2's Avatar
You can reuse the weather stripping, but the metal piece underneath is too thick with the plate. You might have to drop the hood from a little higher up.
Old May 28, 2004 | 04:15 AM
  #28
Bass's Avatar
[QUOTE]Originally posted by Road Rage
Old May 28, 2004 | 06:53 AM
  #29
Road Rage's Avatar
[QUOTE]Originally posted by Bass
Old May 28, 2004 | 07:12 AM
  #30
Bass's Avatar
Ok thanks, haven't seen any others nor have i looked as this was the first snorkle thread i've looked at
But Thanks RR
