For those using synthetic oil...
Unless you are doing things like short trips(<8-10 miles/journey , lots of idling, or lots of cold starts there should be no reason not to go 7-10k per change or meven double that if you change your filter only.
To change a good quality synthetic early, is wasting $$ and you likely would do as well sticking to a good dyno oil.
If you're concerned, then do an analysis every 3K and see if there are problems, actually analysis is a good thing anyway once and a while to tell if there is any unexpected wear.
Search the net for oil analysis. There are several good ones out there (Analysists is one). It will cost ($20-30) bucks/test but it will give you some confidence.
Originally posted by hygiene boy
Ditto!(mobil one synthetic)
_________________________________________________
"S" badges everywhere, Muz x brace, funnel ram cold air extension, carbon fiber interior, del sol spoiler, custom S.T.B. & C.A.I., stock back wheels on the front( I can rotate my tires), blue seats and door panels, clear side markers, aaooggaa horn
I've read on this board that the wheel size on the S2000 must be larger in Back than front otherwise the resulting Handling could be dangerous.
You may want to look into that.
You might want to consider oil analysis with extended oil changes. I've spent years changing my oil once a year using Mobil1 (changing filters every 5k miles) but decided to be more scientific this time around since this car's a keeper. Check out this thread for more details and a copy of my latest analysis...
I'm thinking about changing my oil every other time I start the car.. I mean what does Amsoil know with their 25,000 mile oil life change... heck all they are is the professionals in the business and wouldn't know anything more than I would..
but seriously, I change mine at the oil life mark.. using Mobil 1(will start using Amsoil now that I've found a place that sells it for not much more than Mobil1)
