JR Filter users - oil analysis?
For all the JR filter users, has anyone done an oil analysis for Silicone content?
K&N is doubtful in filtering efficiencies so is the JR any better since basically they share the same philosophy of filtering.
I have had two analyses with the JR filter and the third one is in the mail. So far, there has been no problem noted (I'm down to 6k miles using Mobil 1 10W/30 and Honda oil filters):
JEFF: Lowering the oil use interval by 1,000 miles really did not make much difference in the wear levels, so if you are comfortable with these levels, you may want to continue in the 8,000-mile oil use
range. Iron continues reading high, but we think it's going to stay up there as long as you use this oil interval. The TBN read at 10.0, showing plenty of active additive left in the oil. Insolubles (oil filtration) were close to limits at 0.5%. Silicon (air filtration) looks good at 6 ppm. No fuel, moisture, or antifreeze found.
Originally posted by SECRET AP1
Jeff, where do you send your oil to be analyzed, and how expensive is it?
I don't recall the exact charge but it's ~$20 for the basic analysis and $10 more for the advanced work useful for extended change intervals afforded by synthetic oils.
Originally posted by FormerH22a4
That is excellent, what is your air environment like? Is it dusty where you are? Do you drive in the winter?
So, not particularly dusty - I'd guess more or less like your climate...
