threw a rod
Old Dec 16, 2005 | 05:32 AM
  #21
chadcyn's Avatar
Originally Posted by KAY'S,Dec 16 2005, 06:17 AM
Honestly thats what usually happens here. Can we please stop posting miss information. And Xviper can hook you up with a custom water shield for everyone else that has cold airs that is scared of hydro locking.
Old Dec 16, 2005 | 06:41 AM
  #22
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Hard to beleive,with so little water.
Yes,you can hydrolock an engine,and rod failure can occur,but it takes quite a bit of water.!!!
I remember,back in the old days,I used to "de-coke"engines,mostly smallblock Chevy engines,(and up to 12.5 to 1,comp.ratio)by pouring bottles of water in the carburators.!!!
Old Dec 16, 2005 | 07:32 AM
  #23
dhayner's Avatar
...And Xviper can hook you up with a custom water shield for everyone else that has cold airs that is scared of hydro locking.
Just remember that xviper's shield will keep rainwater from coming in from the top, but won't help sucking up deep water from below.
Old Dec 16, 2005 | 07:58 AM
  #24
KAY'S's Avatar
his filter is in his engine bay hahah so unless you take it to the window line i think your alright...........
Old Dec 16, 2005 | 10:24 AM
  #25
CIVICTOS2000's Avatar
I need to get hooked up by xviper......
D.
Old Dec 16, 2005 | 10:56 AM
  #26
Dark_Sub_Rosa's Avatar
I'm not understanding how water is getting into the engine with a stock box and etc. The opening is small for water to get in, then it has to be soaking the filter enough to pull through the filter.
I understand hydrolocking but it sounds a lil fishy if the water isn't that deep. Can someone explain how it's getting in the engine if the water is so freaking low.
Old Dec 16, 2005 | 11:50 AM
  #27
j_c_a's Avatar
I can only speak for my case but what i *think* happened was that the front bumper acted like a plow, pushing a sheet of water over the nose of the car. So even though the standing water level was only about mid wheel, the "effective" water level at the nose while moving was enough to get into the airbox.
Hindsight being 20/20, what i should've done was turned the car off, walked away and dealt w/ the wet carpet later.
Old Dec 16, 2005 | 01:51 PM
  #28
Wisconsin S2k's Avatar
it takes as little as a mere 100cc's of water into the engine to hydrolock it
Old Dec 16, 2005 | 02:35 PM
  #29
2005S2K's Avatar
That is just over 3 ounces. You probably gulp more than that when you are thirsty. That is not very much water to hydrolock an engine!
Old Dec 16, 2005 | 03:04 PM
  #30
raymo19's Avatar
[QUOTE=Emil St-Hilaire,Dec 16 2005, 11:41 AM]Hard to beleive,with so little water.
