Timing Chain Tensioner
Old May 15, 2007 | 04:09 PM
vtecissexy's Avatar
Default Timing Chain Tensioner
So I replaced my timing chain tensioner about 3k miles ago (was making that horrid sound) and everything has been good. But about 100miles ago I started to notice the noise again at startup. This was how the old one was...at first it was only at startup you could hear it then it just got progressively worse... wtf is up with these things? anyone else have this problem?
Old May 15, 2007 | 08:35 PM
TheDonEffect's Avatar
You sure you installed it correctly? I mean I heard about them going bad again fairly quickly, but this is pretty quick. Did mine about 7000 miles ago, no problems (matter in fact, I think I didn't even need to do it... anyway).
Btw, I think this should be in the UTH forum.
Old May 16, 2007 | 06:42 PM
vtecissexy's Avatar
I'm positive I installed it correctly. Thing is a piece of cake. Yea, this should prolly be in the UTH forum. My bad =]
Anyone, ideas?
Old May 16, 2007 | 07:54 PM
Sabre's Avatar
Some speculation I have heard is that if your oil gets low, it can cause it to start acting up again prematurely. The unit operates on oil pressure.
I changed mine about 2k miles ago, no problems yet. 46k on the clock now.
Old May 16, 2007 | 08:01 PM
ShocK's Avatar
I changed my oil yesterday on startup it made a ton of noise, these things must be crap.
Old May 16, 2007 | 08:29 PM
Hrm...that is weird, did you pull the pin before you put in and did you do the other method of pulling the pin and then installing it?
I dunno, just searchign for a reason besides what seems to be a defective part... got an oil change done with mobil 1 and my engine is purring, forgot how quiet the engine could be, lol <knocks on wood>.
Old May 16, 2007 | 08:30 PM
Oh btw, did you check your old tensioner for damage?
riceball777
Feb 13, 2010 07:26 PM
ap2s2k505
Feb 16, 2009 09:32 PM
AzNxKuKu
Oct 7, 2008 12:45 PM
jdmgpw04
May 7, 2008 02:37 PM
machviper9
May 6, 2007 11:14 AM
