Tips for buying used?
Old Oct 30, 2008 | 09:51 PM
rossifumiwlf@'s Avatar
Default Tips for buying used?
Hi folks,
Seriously thinking about picking up a used S2000.
Any tips on what to look for, what to watch out for, known issues?
I'm not too sussed about what model year to pick up, so long as I can find one in great condition.
thanks
Old Oct 30, 2008 | 10:43 PM
zoomkat's Avatar
Originally Posted by rossifumiwlf@,Oct 30 2008, 09:51 PM
Hi folks,
thanks
Look for one that is totally stock, owned only by one person, and the older the person the better.
Old Oct 30, 2008 | 11:41 PM
alSpeed2k's Avatar
Low kms maybe. Lots of info on this site. Use the search function.
Old Oct 31, 2008 | 01:49 AM
camb0's Avatar
Older the person the better? In most cases yes, in all cases no!
Old Oct 31, 2008 | 03:19 AM
Nick.'s Avatar
make sure every panel has the VIN ID sticker on it.
make sure the car is full with oil, if not, walk away.
make sure the top works along with all other features.
drive the car on the highway and make sure no vibrations at high speeds or anything.
Good luck.
-Nick.
Old Oct 31, 2008 | 06:12 AM
senor_flojo's Avatar
From: All up in your inner tubes. Whatcha gonna do sucka?
drop the clutch around 7k rpm a few times to test out the rear dif
Old Oct 31, 2008 | 06:20 AM
roflitzjinno's Avatar
but really. if youre unsure bring a mechanic with you to check out the car.
Old Oct 31, 2008 | 06:21 AM
hguerrero's Avatar
documented maintenance speaks volumes
Old Oct 31, 2008 | 07:29 AM
teledog's Avatar
I always thought a compression test is a good way to gauge.
Old Oct 31, 2008 | 07:56 AM
howardtan's Avatar
If AP1, there's an assload to look for. 1st to 2nd gear grind (sometimes even 2nd to 3rd), oil burning (common, cannot get away with it period, so check dipstick if it's full), soft top rips are the first to name.
