Tire pressures
Old Sep 10, 2002 | 03:26 PM
DaveFromSydney's Avatar
Default Tire pressures
The handbook says 32 PSI all around (cold).
What do you use?
I use 32 PSI in the city.
I use 34 PSI for high speed driving in the country.
I am going to my first track day where +5 PSI is recommended, i.e. 37 PSI.
Does anyone else use more? Or differing front-rear values?
How much should I allow if measuring when the tires are hot?
Old Sep 10, 2002 | 03:55 PM
Strike's Avatar
37, if it's the cold pressure, seems high to me. I've run a max of 36 at the track. If you run 37 cold you'll be in the 43-44 range hot. I'd start with 34 and adjust for subsequent run sessions based upon conditions, tire roll, etc...
Old Sep 10, 2002 | 04:38 PM
liquid215's Avatar
i run 34 for the rear tires & 33 for the fronts.
Old Sep 10, 2002 | 05:40 PM
DavidM's Avatar
When I had S02s I settled on 40/35psi (front/back) cold - worked best for best for me on the road as well as on the track. Anything less than that and I was unhappy with the car.
Old Sep 10, 2002 | 06:44 PM
yellow2001's Avatar
i run 32 all around. I have try higher, but the ride is very boucey
Old Sep 10, 2002 | 07:04 PM
skynet's Avatar
i run 35 all around.
Old Sep 11, 2002 | 02:03 AM
KIDS2000's Avatar
same here
35psi on my 17s
215/45/17
235/40/17
Old Sep 11, 2002 | 02:26 AM
Muz's Avatar
Muz
Former Sponsor
35 all round here. I find this perfect for me. 34 is too soft, 36 is too hard. Dealer recommended it also.
VelocityXvolumE
Apr 18, 2011 07:38 PM
blkblks2k
May 8, 2008 12:33 PM
W31
Jul 3, 2006 12:48 AM
Saki GT
Jun 6, 2006 05:01 PM
JerryIII
Apr 19, 2005 12:25 PM
