Tire pressures
The handbook says 32 PSI all around (cold).
What do you use?
I use 32 PSI in the city.
I use 34 PSI for high speed driving in the country.
I am going to my first track day where +5 PSI is recommended, i.e. 37 PSI.
Does anyone else use more? Or differing front-rear values?
How much should I allow if measuring when the tires are hot?
What do you use?
37, if it's the cold pressure, seems high to me. I've run a max of 36 at the track. If you run 37 cold you'll be in the 43-44 range hot. I'd start with 34 and adjust for subsequent run sessions based upon conditions, tire roll, etc...
