Tires are wearing from the inside
Old Jan 17, 2003 | 05:27 AM
scottrnelson's Avatar
My first set of front tires got more wear on the inside than the outside because the car needed an alignment. It has always been driven through plenty of turns at high speed.
I get it realigned now whenever I put new tires on it. It wears the tires evenly when it is aligned correctly.
Old Jan 17, 2003 | 08:16 AM
Roadruler's Avatar
So your telling me if you drive hard the tires dont wear out like this. So when you do drive hard, how do your tires wear. I defintely drive hard, not all the time though.
Old Jan 17, 2003 | 08:56 AM
[QUOTE]Originally posted by Roadruler
[B]So your telling me if you drive hard the tires dont wear out like this.
Old Jan 17, 2003 | 11:14 AM
Kekoa's Avatar
Yes, allignment is key. I have an aggressive street allignment with 17 inch rims dropped on KG/MM race. I haven't noticed any uneven tire ware yet and I drive my car daily.
I've had tires blow on a past car with crappy allignment and I don't wish that on anybody. Bent two of my rims.
Old Jan 18, 2003 | 04:33 AM
dlq04's Avatar
Originally posted by 2kturkey
Totally normal for fronts - not for backs though, DLQ.
I stand corrected. However, we are BOTH wrong. I was basing my reply on my personal experience and what I'd read in other tire wear threads -- all of which delt with rear wear. On my car it's the right rear that first showed wear. I just did a search using "tire wear" and was surprised to see there are numerous threads for inside wear on both rears and fronts. My fronts show no wear at all with 11,000 miles. So I've learned something. There are some threads that speculate the inside right rear wear is due to the owner's launching the car and inturn the diff applying force to the right rear wheel first. That may be how the diff works, I don't know for sure, but I can honestly say I've never launched the car from a standstill. I just don't believe the drive train can withstand that over a prolonged period of time.
So, the bottom line is -- depending on your car, your driving style, your air pressure, your alignment, or whatever -- in some cases the fronts wear first and for others the rears wear first but both seem more likely to wear on the inside than the outside.
s2kdriver80
Nov 17, 2011 09:31 PM
s2kZac
Oct 8, 2009 08:17 PM
groundzero
Nov 21, 2006 09:21 PM
Gernby
Sep 15, 2003 07:07 AM
QT_S2K
Mar 2, 2003 08:18 AM
