Top Leaking
Old Oct 14, 2005 | 05:06 PM
themush1326's Avatar
Default Top Leaking
I hear a sloshing sound that seems to happen right after a heavy rain.
It sounds like its about ear level on the passenger side.
It does smell a bit damp but I can find significant water accumulation.
I can only fell a little moisture behing the passenger seat about half way up under the placstic.
It doesnt even go thru the carpet, only the padding feels damp.
Any thing I can check or unclog?
I'm taking it to the dealer but already tell me not to count on a warranty repair for leaks if it a clogged drain.
Any ideas would help, it an 02 S2000 with 26k CPO.
Old Oct 14, 2005 | 05:49 PM
xviper's Avatar
At the base of the soft top on each side, there are channels that let the water run away when you wash the car or when it rains. You might want to check those channels to see if they are blocked. If they're blocked, water can get into the car.
Old Oct 14, 2005 | 06:10 PM
PopTarts's Avatar
I've had a similar problem but near where the frame, top and window all come together. Doesn't seem to leak in lighter rain though... only during heavy rain.
I just had some body work done (replacing the rear quarter panel) and I'm wondering if it wasn't put back together tightly enough...
Old Oct 15, 2005 | 03:37 AM
thanks, whats the best way to see these channels?
Do I need to lower the top?
Old Oct 15, 2005 | 04:30 AM
spider2k's Avatar
Active Streak: 30 Days
the empty out right in front of the rear wheels. youll have to remove the center and side plastic pieces in the rear . you will see what looks like a square funnel.
when i replaced my soft top the water was coming iside the car and i found out these were badly clogged. i took a towel and laid it above the "funnel", then put an air nozzle in where it exits at the wheels. a few good blasts and it got the gunk out. then they worked perfectly.
Old Oct 15, 2005 | 04:55 AM
sorry to be so dense but are you talking about inside the car or the fender liner
outside?
thanks
themush
Old Oct 15, 2005 | 05:50 AM
any links or posts on how to unclogg the drains?
murd0x
Apr 29, 2010 12:40 PM
mrxwormxsayz
Nov 28, 2008 09:07 PM
TRDLiquidSilver
Nov 5, 2007 12:21 PM
WizardOfAhs
Jun 16, 2006 09:25 AM
Mannix16
Oct 26, 2005 05:13 PM
