Top and window problems.
Old Aug 14, 2010 | 10:03 PM
AndrewShaffer's Avatar
Default Top and window problems.
Okay my top and passenger window will not go down..I made sure i had the e-brake engaged, out of gear, and the window lock in off and not moving..I also checked all the fuses in the car and under the hood..None of them are blown..But here is the catch..My driver side window goes down wtf?? HELP!!! I cant stand driving with the top up on beautiful days!!
Old Aug 15, 2010 | 12:33 AM
F22C S2K's Avatar
I had the same problem about to months ago but the window would not go up. I did a mini diagnosis like you just mentioned and nothing. And then I took the door panel off and unpluged the window connector, than started the car and let it run for about thirty seconds, then I plugged in the connector again and then restarted the car and tested it out and it worked fine. It worked for me hope it works for you.
Best of luck
Old Aug 15, 2010 | 05:30 AM
common reactor's Avatar
If you have to, take it to autozone or a private mechanic. Stay away from the stealership at all costs.
Old Aug 15, 2010 | 07:57 AM
Okay thanks for the help..Ill doing all that today see if i get lucky..
Old Aug 15, 2010 | 12:57 PM
Ok so i tried all that and nothing worked..I am thinking there is a BAD relay somewhere or the power control module went out..
pkolaboy
Aug 25, 2012 01:43 AM
nwaaa11
Nov 24, 2010 02:27 AM
TJF
Oct 28, 2010 12:06 PM
s2ke5
Nov 4, 2007 04:32 PM
George
Nov 25, 2000 03:00 PM
