Top Won't Go Down
Old Aug 21, 2007 | 06:05 PM
rocrfella's Avatar
Default Top Won't Go Down
I was driving for about an hour or so today and I wanted to lower the roof. I pulled it back and hold, but nothing happened. So I shut off the engine and pulled the key out. And started it back up again, this time it went down, but then again I drove for a little bit more then it was time to put the top back and it won't go up. I had to repeat what I did previously twice or so then it went up. Does this ever happen to your car?
Old Aug 21, 2007 | 06:09 PM
CKit's Avatar
Nope. Ebrake cable loose?
Old Aug 21, 2007 | 06:11 PM
WashabiS2K's Avatar
or is your ebrake even up?
Old Aug 21, 2007 | 06:13 PM
rocrfella's Avatar
You know the sound (click) when press on the button to lower your windows and also when lowering the top. I didn't hear that sound. Weird.
Old Aug 21, 2007 | 06:14 PM
rocrfella's Avatar
You need to pull the ebrake up to lower the top?
Old Aug 21, 2007 | 06:23 PM
Project22a's Avatar
It needs to be up in order to put the top up or down.
Old Aug 21, 2007 | 06:25 PM
Wildncrazy's Avatar
NO, THAT'S NOT IT!!
DON'T DO IT AGAIN!!
What you have are elastic bands that have lost their elasticity. It doesn't pull the middle bar down and when this happens FIST SIZE HOLES APPEAR IN THE TOP JUST BEHIND THE LATCHES.
Modifry has replacement bands.
Old Aug 21, 2007 | 06:30 PM
CKit's Avatar
(That's what I was thinking, but didn't want to assume the noob was that noobish)
Old Aug 21, 2007 | 09:01 PM
tsanhd's Avatar
if your ebrake isn't already up then some cables is probably loose or something around that realm
Old Aug 21, 2007 | 09:07 PM
Jacques79's Avatar
Your ebrake needs to be up and then you press the button for the top.
2 years ago in the middle of winter here in Montreal I put the top down for a few minutes because I just got the car.... and it was freezing...I didn't know how to put the top back up with the e-brake thing so I had to drive 30 mins in -15 degree C weather to get back to my garage....
so there you'll feel better now
