Is the transmission fluid changed when they replace clutch?
Old Dec 6, 2001 | 10:37 AM
ok2k's Avatar
Default Is the transmission fluid changed when they replace clutch?
I'm going in tomorrow (Dec. 7) to get the latest clutch replacement (PCX-055) -- I'm right at 15000 miles -- so I'd kinda like to get the transmission fluid changed while I'm at it -- Will they be changing the fluid anyway since they'll be removing the transmission??
I'll give updates after the fix -- this is the second clutch -- the noise just keeps coming back!
Old Dec 6, 2001 | 06:38 PM
SkipX's Avatar
Yes
Old Dec 6, 2001 | 08:11 PM
Utah S2K's Avatar
Actually the answer is No not Yes (Ref: Helm Manual 12-7). Severe driving requires a fluid change at 30K. If you do get the fluid changed you might want to have it checked. Email "www.blackstone-labs.com" for a sample taking kit (free). For 12-15 bucks they can give you a hard metal count and compare it to other samples which have been submitted. Do a search on Blackstone Labs if your curious.........
P.S. Tell em Utah sent ya and you may get an S2K discount as they are developing a model database on all our fluids.
Utah
Old Dec 7, 2001 | 06:43 AM
ok2k's Avatar
Will do, Utah -- thank you!
She goes in at noon today -- I'm scared!!
Old Dec 7, 2001 | 09:03 AM
jschmidt's Avatar
The answer is depends but probably not. Here's why:
1. It is not necessary to change the tranny fluid to replace the clutch. 2. It was done as a no charge courtesy two times a decade apart when I had new clutches installed.
Henwee
Apr 10, 2015 06:25 AM
HarryD
32
Jan 14, 2013 07:38 AM
vtidan
Nov 11, 2011 11:10 AM
acn684
Aug 16, 2011 09:36 AM
LNKs2k
Jan 10, 2009 04:59 PM
