Transmission fluid less than 1.7 qts?
Old Nov 24, 2006 | 10:31 AM
gtg749m's Avatar
Default Transmission fluid less than 1.7 qts?
I have my car up on four jacksgtands. emptied the fluid. put in new fluid but can only get in about 1.25 qts before it starts to overfill. what am i doing wrong?
Old Nov 24, 2006 | 10:46 AM
s2k dre's Avatar
it takes 1.5 quarts, thats all.
Old Nov 24, 2006 | 12:40 PM
SpitfireS's Avatar
Is the floor level?
Old Nov 24, 2006 | 12:43 PM
s2kshift9k's Avatar
no more than a quart and half
Old Nov 24, 2006 | 01:20 PM
beanolo's Avatar
That sounds about right.
Old Nov 24, 2006 | 01:56 PM
Jsmply's Avatar
If the floor is level you should be able to squeeze in about 1.5 or so quarts. I usually jack it up from the drivers side (and use a jackstand), fill it as much as possible (usually about 1.75 quarts) . . . then jack it back down and let the excess drain out and then cap it.
Make sure your ground is level, the tranny does not take much fluid so you don't want to leave some out.
Old Nov 24, 2006 | 05:01 PM
thetz99's Avatar
I like to jack the passanger side higher to drain as much old fluid out, then I jack the drivers side up to overfill as much as I can. I can squeeze close to 2 quarts in.
Old Nov 25, 2006 | 04:45 AM
stealthx32's Avatar
Don't you think Honda would have moved the fill hole further up if they deemed it necessary to have more capacity...?
Old Nov 25, 2006 | 07:28 AM
VAD's Avatar
VAD
A slight overfill is not a bad thing:
https://www.s2ki.com/forums/index.php?showt...0&#entry7837163
Danwolski
Jun 29, 2012 11:49 AM
StormTroopinAP2
Nov 3, 2011 08:51 AM
jdmjeff
Jan 11, 2009 07:38 AM
TwistedS2k
Feb 28, 2005 02:35 PM
