Trouble in the wet...
Originally Posted by Vitt,Nov 5 2007, 02:32 PM
I think people should instead consider going to a driving clinic, practice on an empty wet parking lot, learn about how weight transfer affects a car under braking, deceleration, acceleration, and be aware that RWD behaves very differently than FWD cars that understeer. But Keep the S, even if you have to drive like grandma in the wet until you master the car, so be it.
Most cars out there are engineered to understeer, especially FWD cars. That's a safeguard engineered in the car by the manufacturers largely for safety and legal purposes. That's why when you drive the S2000 you experience such a contrast.
And yes, VSA only works to stop or slow a spinning wheel that was accelerating, but it can't help when the rear tires have broken traction sideways.
Big, empty, parking lots are great places to slide a car around, but if the parking lot is not gated, it is probably illegal, and potentially dangerous. If you look at the little animated gif in my signature you can see how easy it is to slide the car around and keep it under complete control, even in a tiny gated parking lot, but most people will not have that level of control at first, so it's best to start out in a lot with plenty of space.
A good driving school is infinitely better than solo practice, but there are some basic exercises that can help improve a number of our basic skills. Assuming that one has a safe and legal place to do this stuff ...
Start out with this one: Car stopped, wheels turned all the way to the left or right (full steering lock). Let the clutch out normally and start driving slowly - you'll be turning a very tight circle. Now, start to accelerate *gently*. Continue to speed up, until the car slides or spins out of control, then immediately clutch in and wait for the car to come to a stop. Do this several times, turning in both directions. Do it on both wet and dry surfaces. It's a quick way to get a feel for the amount if grip the tires can deliver, and that's a good place to start.
Next: Get some pylons and set up a large skidpad (just a big circle). Drive around the circle at increasing speeds, until the car is right at the point where it wants to slide off course, and HOLD IT THERE as you continue to negotiate the circle. This may be (and probably will be) difficult at first, but this is the best way I know to learn how to sense the impending loss of traction. The S2000 doesn't give a lot of warning, so your limit sensor needs to be well tuned. Be sure to practice in both directions, and on both wet and dry surfaces. Add ice and snow to the practice list if you drive under those kinds of conditions.
Third: Set up two pylons and learn to "drift" (I hate to use the word becaue it has been mutulated by the sport of drifting, but it's the correct word so I'm using it anyway) a figure 8 around the pylons. Since you will already be able to hold the car on the edge of a slide (from the previous skidpad practice) all you'll really be doing here is adding throttle to *make* the tail slide out more, and this will teach you to both make it slide, and stop it from sliding, at will. Plus (and more importantly) it will teach you to handle the car as it transitions from sliding (or cornering) hard in one direction, to cornering hard in the other direction. As before, do this in the wet and dry, and on ice and snow if appropriate for your situation.
The above will help hone a number of skills one needs to drive a car like the S2000, and they're really basic skills that you can need at times, even if you drive the car like a 60 year old man.
(For the record, I'll be 60 soon.
)Driving like a grandma in the wet isn't always going to be enough, because as others have pointed out, it's all to easy to hit an oil/water mix or other "road hazzard" that can put the car into a slide unexpectedly. Even grandma needs to learn to handle her S2000 in a slide, because if she drives the car long enough she'll need the skills sooner or later.
FAR FAR better than a parking lot is a good school, and the best and cheapest quality schools are held by Evolution. They are intended for autocrossers, but nothing teaches car control any better than autocrossing, so if you really want to learn to drive the car well (at less than track speeds) you just can't beat an Evloution Phase 1 school. If one wants to learn to drive the car well at higher speeds, then both Panoz and Skip Barber (among others) have very good schools.
A good school can be worth more than years of weeked seat time.
Originally Posted by RED MX5,Nov 5 2007, 03:02 AM
I have no idea what happened to you, but I'll say without reservation that my early AP1 is not that volitle, even with the supercharger, gears, and other mods, and your car should be less so, so to tell the truth, your story sounds impossible, unless your tires are more worn than you realize. You have to measure the tread depth on the INSIDE of the tires, and I'm betthing you're out of tread on the inside of the back tires. If you're not, you should seriously consider selling the S2000 and getting something with more forgiving handling (or do as CKit suggested, and put a RaceLogic Traction Control system on your car).
You should clearly NOT be having this kind of problem if you're driving the way you say you are and the tires are really OK.
Is it possible that you hit an oil slick or something else that might have caused the loss of traction?
Going 20-25 mph and hitting a bump in the road shouldn't send you flying into a wall. If that were the case, probably 50%+ of the S2000's made would already have been totalled!
[QUOTE=RED MX5,Nov 5 2007, 04:09 PM]
Originally Posted by trinis2001,Nov 5 2007, 06:53 PM
Red MX5,
Do you mind me using this very well said discourse on my autoX club's forum/website? I would like to get them to start holding such practice sessions and think your description of basic practice could help us quite a bit.
BillyB
BillyB
Have you ever been to one of the Evolution schools?
Originally Posted by C U AT 9K,Nov 5 2007, 03:49 PM
Going 20-25 mph and hitting a bump in the road shouldn't send you flying into a wall. If that were the case, probably 50%+ of the S2000's made would already have been totalled!CKit may be right. The bump may have caused a little sidestep at the back that scared the driver into getting off the gas suddenly and unbalancing the car at the worst possible time, but there could be other factors involved too.
LOL, I do think that probably at least 50% of all S2000 owners spin their car at least a once. Some do it in a safe environment to learn to deal with problems, and others do it accidently in the worst possible environments, but I think most of us do it, sooner or later. Fortunately, most people don't total the car when they spin.
Originally Posted by trinis2001,Nov 5 2007, 07:19 PM
^ Yes totally non commercial : www.carstt.com
Me and my buddy (Evo VI RS2) are planning a vacation to the US next year just go to "school". Most likely in the Florida area, but we will go wherever the best place(s) is to go - after all - it will need to be a vacation for the missus too!
I will check out Evolution on the web and see where that gets me, but if you can make some specific recommendations......
While the second exercise I mentioned previously is appropriate for an autocross school, the fist and last involve sliding the back end of the car around by spinning the tires, and are more appropriate for learning to handle slides than for learning to turn a good autocross time. Many (if not most) autocrossers won't be real fond of the idea of burning up their back tires just to learn to control a slide.
Use a skidpad circle to practice grip sensing, but forget the other two exercises. Instead, use some of the classic exercises like a Chicago Box, chicane, circus, and so on. Set up a mock autocross course that includes all the elements, and focus on each persons weakness, which will often be either bad line or failure to look ahead far enough. If you can get professional instructors from a place like Evolution, each student will get individualized instruction based on their specific needs, so while it might be expensive to fly instructors to your location, it would be cool if you could find someone down your way.
If you can plan your trip to coincide with an Evo school you won't be sorry.
And to answer your question regarding all season tires.....
Yes, they make a huge difference. I have had Pirelli P Zero Nero M+S on my 04 for two years now. I drove safely through all those snow storms last year in Seattle. Also, they do help greatly in the rain when temps are cold. Down side is that handling is not as good as with summer tires.
