UK Alignment?
Old Feb 13, 2008 | 07:01 AM
KeithM's Avatar
FYI, the squares you see are a degrees sign. For some reason it doesnt translate over when I copy and paste from an outside source.
Old Feb 13, 2008 | 08:10 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Old Feb 13, 2008 | 08:15 AM
Ouhei's Avatar
I have the UK spec on my AP1, it felt much more planted afterwards.
I haven't noticed terrible tire wear, but from all consensus they do wear faster.
Old Feb 13, 2008 | 09:03 AM
tekstar's Avatar
Originally Posted by KeithMajkasays,Feb 13 2008, 07:59 AM
UK TSB Wheel Alignment Recommendations
Honda UK settings are published in degree/minutes and some machines take inputs in decimal degree which is translated by = sign.
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Front 6 deg 45 min = 6.75̊
Total Toe
Front 0 mm
Total Toe 0 deg 40 min (0 deg 20 min per side) = +0.32̊ (+0.16̊ per side)
wouldn't total toe 0 deg 40 min = 0.67 degrees (0.33 per side)
Old Feb 13, 2008 | 09:11 AM
LEE72's Avatar
Anyone with input on an AP2 with the UK alignment?
Old Feb 13, 2008 | 09:39 AM
ThatPreludeGuy's Avatar
Perhaps this out there somewhere already but it would be great to have a FAQ for this. Maybe something that lists the following:
Ex.
MY: 2000
Suspension modifications: 1" drop on Tanabe GF210, OEM AP2 wheels and tires
Alignment Specs: UK alignment
Desired results: DD and occasional Auto-X
Opinions: Feels great, tires wore on inside approx 5k faster then USDM alignment
Might be easier for people in the future to get an idea of what will work for them and what to expect when doing a non US standard alignment.
Old Feb 13, 2008 | 11:00 AM
nzouk77's Avatar
I have the UK alignment on an '08, but don't have enough miles on the car to talk about tire wear - I am running RE-01R's. Will be happy to get 10k miles.
Back end is harder to kick out from what I can tell so far.
Old Feb 13, 2008 | 11:07 AM
gtg749m's Avatar
I ran hankook rs2's with us alignment. my tires wore evenly and the rears lasted roughly 12k+.
got a new set of rs2's for the rear, lowered the car with espelirs, and now running uk alignment. im at roughly 10k now and still got a little tread left. i should hit 11k+ just fine and tires do seem to be wearing quite evenly.
so from my personal experience, i am going to get roughly the same mileage with uniform wear with uk alignment.
Old Feb 13, 2008 | 11:51 AM
Amer's Avatar
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Total Toe
Front 0 mm
Thanks, I couldn't find the UK alignment when I did mine.
Old Feb 13, 2008 | 02:01 PM
KeithM's Avatar
Not a clue. I just got it from searching.
