Understeer?
Originally Posted by CA_S2K,Sep 27 2007, 08:46 PM
i was having a discussion with my brother and he also want to get an s2k and he plans on eliminating the oversteer, is that possible? i told him i dont think so.
And yes it's definitely possible for an S2k understeer...it happens when you make a driving mistake. Happened to me at the track once when I pushed into a corner too fast...not a good feeling.
Most people think not oversteering = understeering. Understeering is NOT good, understeering is one of the scariest things that could happen while your driving. Imagine having the wheel turned, but your car keeps going straight, that's understeer.
Originally Posted by Pointblank,Sep 27 2007, 07:50 PM
Yes, by learning how to drive better. As bad as that sounds, it's the honest truth. You could get stickier tires to help hide it, but that'll just give him a false sense of confidence in his driving.
Dive into a corner late..... Ap2s will understeer! (at least an 06), partly my fault, otherwise the change in spring rates, which honda changed to reduce the snap oversteer found in the Ap1s. I feel the AP2s have been neutered of a bit of balance, softening the rear to actually push deep in a corner. Im trying to find somewhere tween... with aftermaket springs.
Originally Posted by CA_S2K,Sep 27 2007, 10:33 PM
is there any way possible a s2000 can have understeer?
Put larger tires on the back relative to the front, remove the RSB, add a really stiff FSB, and downsize the front tires, and you can make the car plow like a pig, if that's what you're looking for. Same thing pretty much applies to any car. Handling can always be dialed in to suit a particular venue or driving style.
FWIW, I agree that the early AP1's could be a little quicker with a little less oversteer.
