Using Coilovers
Old Mar 11, 2008 | 07:33 PM
duanet85's Avatar
Default Using Coilovers
Hey guys, if this is the wrong thread, please move it and post where it was moved to. Thanx!
Ok so guys i'm looking into getting a set of coil overs this summer. Once the coil overs are installed, will it change the camber or toe or anything? Will anything else need to be changed, such as half shaft spacers or anything? Or is it really as simple as Remove old and Replace with New...good to go?
Old Mar 11, 2008 | 07:44 PM
sirbunz's Avatar
Might get a better answer in the Racing & Competition section.
You will need to have the alignment fixed/reset. You are changing quite a bit in the dynamics of the suspension by installing the coil overs. If it were me, I would have it corner balanced and put an aggressive alignment on it after putting on the springs. Make sure to let the suspension break in before doing this or it will quickly change once it settles.
Old Mar 11, 2008 | 08:02 PM
duanet85's Avatar
thanx man, note this is a street set up and will not be tracked, dont know if that will make a difference in answers.
Old Mar 11, 2008 | 08:19 PM
harrrrry's Avatar
Yes, once it's installed, drive it for a week or so - maybe go over some uneven roads so the components are really being put to work. After that, get a re-alignment. Or even better, like the first response - get it corner balanced also.
Old Mar 12, 2008 | 10:38 AM
duanet85's Avatar
LOL thats an everyday drive here in Illinois. I just wanted to make sure that there was nothing else needed besides the coil overs and an alignment and possibly corner balancing. It will be my first experience with coilovers so i just want to to things one time the right way.
Orleansjunky
Sep 19, 2017 03:15 PM
HighwayStar
Mar 7, 2011 09:18 AM
darksparkz
Aug 20, 2010 05:24 PM
ApexMotorPro
Apr 26, 2006 11:15 PM
